Upgrade Guide > Performing the Siebel Repository Merge > Setting Label Alignment for Siebel Text FieldsUpgrades from: Siebel 7.x using ICL. Environments: Development environment only. This topic is part of an upgrade process. See How to Perform a Siebel Database Upgrade. At Siebel 7.7 label alignment for fields in forms changed. The label vertical alignment changed from top to middle, font weight changed from bold to normal, and text alignment changed from left to right. If you selected Incorporate Custom Layout (ICL) for the repository merge and chose Label On Top, you must edit the style sheet (main.css) to set label alignment to preserve the look and feel of your previous release. To ensure Quick Print and Print Preview display correctly, you must also revise the print preview style sheet (printmain.css) Revising main.cssRevise main.css to display field labels in pre-7.7 format
Revising printmain.cssRevise printmain.css to display field labels in pre-7.7 format in Quick Print and Print Preview.
| Upgrade Guide | Copyright © 2006, Oracle. All rights reserved. | |
