Upgrade Guide > Performing the Siebel Repository Merge > Deleting Unneeded Siebel Repository FilesUpgrades: All Siebel upgrades. Environments: Development environment only. This topic is part of an upgrade process. See How to Perform a Siebel Database Upgrade. When you are confident that the repository has been upgraded successfully, export the New Siebel Repository and Prior Customer Repository for safekeeping. You can also delete the following repositories: |
| Upgrade Guide | Copyright © 2006, Oracle. All rights reserved. | |
