Upgrade Guide > Performing the Siebel Repository Merge > Configuring Siebel Repository Objects to Inherit Upgrade BehaviorUpgrades: All Siebel upgrades. Environments: Development environment only. This topic is part of an upgrade process. See How to Perform a Siebel Database Upgrade. As of Siebel 7.7, you can link objects together so that one object inherits the upgrade behavior of another. You do this by specifying an upgrade ancestor for an object. For more information, see About Inheriting Upgrade Behavior in a Siebel Upgrade. You can specify an upgrade ancestor for the following object types: Before doing the repository merge, review new objects you have created and determine whether you want to specify an upgrade ancestor. |
| Upgrade Guide | Copyright © 2006, Oracle. All rights reserved. | |
