Upgrade Guide > Siebel Database and UI Upgrade Planning > About Upgrading Your RDBMS in the Siebel EnvironmentUpgrades: All Siebel upgrades. Environments: Development, production test, production. If your currently installed RDBMS version is not supported in the new release, you must upgrade your RDBMS before performing the Siebel Database upgrade. For information on supported RDBMS versions, see System Requirements and Supported Platforms on Siebel SupportWeb. If your currently installed RDBMS version is supported in the new release, and you plan to upgrade your RDBMS, you can do so before or after upgrading your Siebel Database. The following guidelines and requirements are for planning your RDBMS upgrade. NOTE: When you upgrade the RDBMS, also be sure to upgrade your client database connectivity software. See System Requirements and Supported Platforms on Siebel SupportWeb. Oracle
IBM DB2 |
| Upgrade Guide | Copyright © 2006, Oracle. All rights reserved. | |
