Upgrade Guide > Reviewing the Siebel User Interface > Assigning a Category and Type to Siebel Chart ViewsUpgrades from: Siebel 6.x, 7.0.x, & 7.5.x. Exception: this topic does not apply to 7.x upgrades that used the Incorporate Custom Layout (ICL) feature. Environments: Development environment only. Reputility log section: "Issue 4: Chart Views Needing Migration to Aggregate Type." This topic is part of an upgrade process. See How to Perform a Siebel Database Upgrade. The Chart menu item is relocated as of Siebel 7.7 and displays as one of the aggregate categories under the view tabs.To ensure that the Chart menu item is located correctly, all the relevant charts for a view must be assigned to the same Aggregate Category. Also, each chart view must be of type Aggregate View. If the chart view is not of type Aggregate View, the chart menu item displays as a view tab. The postmerge utilities review the repository and verify that Chart views have been defined correctly. The reputility log lists the screen views that require revision. Review the section of the log referenced above and make the needed revisions.
SIEBEL_TOOLS_INSTALL_DIR is the directory where Siebel Tools is installed. |
| Upgrade Guide | Copyright © 2006, Oracle. All rights reserved. | |
