Upgrade Guide > Reviewing the Siebel User Interface > Reviewing New Siebel UI Aggregate CategoriesUpgrades from: Siebel 6.x, 7.0.x, & 7.5.x. Environments: Development environment only. Reputility log section: "Issue 2: New Aggregate Category Records That Should Be Renamed." This topic is part of an upgrade process. See How to Perform a Siebel Database Upgrade. The following new properties were added to the Screen View object in Siebel Tools to support new UI navigation introduced in Siebel 7.7:
For a description of these properties, see Configuring Siebel Business Applications. If you have created new views or have modified existing views, the postmerge utilities create new Aggregate Category records to support the new properties. The utilities name the new aggregate category records "busobj_name List." For example, a new aggregate category record for the eEvents screen would be named eEvents List. The reputility log lists the category records that were created by the postmerge utilities. Review the section of the log referenced above and make the following revisions as needed to the listed objects:
SIEBEL_TOOLS_INSTALL_DIR is the directory where Siebel Tools is installed. |
| Upgrade Guide | Copyright © 2006, Oracle. All rights reserved. | |
