Upgrade Guide > Preparing Siebel Application Data for Upgrade > Preserving Siebel Marketing Segment DescriptionsUpgrades from: Siebel 6.x, 7.0.x, & 7.5.x. Environments: Production test, production. This topic is part of an upgrade process. See How to Perform a Siebel Database Upgrade. When upgrading from a prior release of Siebel Marketing to Siebel 7.7 or later, the database upgrade overwrites the Description field for all Segment records (S_CALL_LST.DESC_TEXT) with the string "DO NOT USE: Segment from previous release." If you want to preserve segment descriptions, migrate the existing descriptions to another text extension column before running the upgrade. |
| Upgrade Guide | Copyright © 2006, Oracle. All rights reserved. | |
