Upgrade Guide > Basic Database Preparations for a Siebel Upgrade > Securing AIX Memory Allocation Segment Space for the Siebel DatabaseUpgrades: All Siebel upgrades. Environments: Development, production test, production. Databases: All databases. (Exception: this topic does not apply to MS SQL Server.) This topic is part of an upgrade process. See How to Perform a Siebel Database Upgrade. Before you run an upgrade on AIX, set the following environment variable on the AIX machine that you are using for the upgrade:
This will prevent a shortage of memory allocation segment space that might occur on the machine where both the Siebel Database Server and Siebel Server are installed. After a successful upgrade, reset this parameter to the original value. |
| Upgrade Guide | Copyright © 2006, Oracle. All rights reserved. | |
