Upgrade Guide > Preparing an Oracle Database for a Siebel Upgrade > Verifying Oracle Database Sort Order for a Siebel UpgradeUpgrades: All Siebel upgrades. Environments: Development, production test, production. This topic is part of an upgrade process. See How to Perform a Siebel Database Upgrade. The NLS_SORT parameter determines the sort order of query returns. NLS_SORT must be set to BINARY for the development environment upgrade, including the repository merge. It must also be set to BINARY when using Siebel Tools to compile an SRF file. This setting is strongly recommended for production test environment upgrades and production upgrades. Related TopicAbout Database Sort Order in the Siebel Environment |
| Upgrade Guide | Copyright © 2006, Oracle. All rights reserved. | |
