Upgrade Guide > Preparing an Oracle Database for a Siebel Upgrade > Verifying the Oracle Database ODBC Definition for a Siebel UpgradeUpgrades: All Siebel upgrades. Environments: Development, production test, production. This topic is part of an upgrade process. See How to Perform a Siebel Database Upgrade. When you install a Siebel Server, the installer creates the ODBC definition for the Oracle database you specify. When you upgrade your production test environment and your production environment, you must manually create an ODBC definition for connecting to your development environment database. If the development environment database is Oracle 9i, you must edit the ODBC definition after it has been created. To verify or edit an ODBC definition under Windows
If these entries are not present, right-click in the data display pane and choose New > String Value to add them. |
| Upgrade Guide | Copyright © 2006, Oracle. All rights reserved. | |
