Upgrade Guide for DB2 UDB for z/OS > Upgrading a Database from the Mainframe > Executing the Upgrade on the z/OS Host (Phase 1 of 2) >
Migrating Product Configurator Data for FINS
Complete the following procedure to migrate Product Configurator data for Siebel Financial Services (FINS) applications. Prerequisite task: Migrating Product Configurator Data. NOTE: This topic applies to upgrades from Siebel Financial Services (FINS) 6.2.1 and 7.0.4 (not SIS 7.0.4) applications.
To migrate Product Configurator data for FINS applications
- If you are not on the Siebel Upgrade Main Menu, enter the following command:
TSO SBLUPG78
- Select option 5: RUN UPGRADE / POST-UPGRADE MAINTENANCE.
The Siebel Upgrade Job Submission Menu for your upgrade path appears.
The panel ID is SBLRUNFP.
- Select option 10: PROD CONFIG-FINS.
This places you in edit mode for dataset DSNHLQ.SIEBEL.INSTALL.JCL(SUBPCF).
- Run the job using the JCL in dataset
This job automatically submits the first PRODCFGF job stream. If this job runs successfully, it automatically submits the next dependent job, and so on. This process continues for all PRODCFGF jobs. If a job fails, the succeeding dependent job does not get submitted. The automatic job submission sequence terminates.
- After the job is run, verify that the job ran successfully.
RC=0, RC=4, or RC=8 indicates that the job was successful. RC=8 is associated with jobs that have an X in position 3 of the member name.
Jobs with an ABEND (end abnormally) U99 or U099 message are jobs that failed.
If you selected Siebel-Scheduled Mode, this job is logged (as Completed Successfully or Failed) to the target Siebel log table: TARGET_TABLEOWNER.TMP_SBLLOG_TAR.
NOTE: You must fix any failed jobs before proceeding with the upgrade. For information on restarting failed jobs, see Restarting Failed Jobs on the Mainframe.
- After submitting the job, enter
cancel on the command line or press PF3 to save changes.
- View the job status.
For information on how to view job status if you selected Siebel-Scheduled Mode, see Viewing the Siebel Job Log Status.
