Upgrade Guide for DB2 UDB for z/OS > Upgrading a Database from the Mainframe > Executing the Upgrade on the z/OS Host (Phase 2 of 2) >
Rebuilding the Gen Primary 7.8 Indexes
Perform the following task to submit the rebuild jobs for the 7.8 Gen Primary indexes. To rebuild a primary index
- Make sure you are at the Siebel Upgrade Job Submission Menu for your upgrade path.
- For Siebel Business application upgrades, the panel ID is SBLRUNHP.
- For Siebel Industry application (SIA) upgrades, the panel ID is SBLRUNFP.
- Select the option for the application you are upgrading.
- Run the job using the JCL in dataset
DSNHLQ.SIEBEL.INSTALL.JCL(SUBGPREX).
Verify that the job ran successfully (RC=0 or RC=4). Jobs with an ABEND (end abnormally) U99 or U099 message are jobs that failed.
If you selected Siebel-Scheduled Mode, this job is logged (as Completed Successfully or Failed) to the target Siebel log table: TARGET_TABLEOWNER.TMP_SBLLOG_TAR.
NOTE: You must fix any failed jobs before proceeding with the upgrade. For information on restarting failed jobs, see Restarting Failed Jobs on the Mainframe.
- After submitting the job, enter
cancel on the command line or press PF3 to save changes.
This submits 2000+ Index Rebuild jobs. The number of Index Rebuild jobs varies by upgrade type. Job names range from ###10001 to ###1nnnn.
