Upgrade Guide for DB2 UDB for z/OS > Preparing Application Data for Upgrade >
Setting Up Campaign Status Values for Siebel Marketing Upgrade
Upgrades: All upgrades. Environments: Production test, production. This topic is part of an upgrade process. See How to Perform the Upgrade. This optional step is not required for upgrade processing, but will simplify program and campaign reporting by making historical values equivalent with the values used as of Release 7.7. The database upgrade process expects the standard Status values for the following applets. The process uses the standard values to convert records to the new campaign model during the upgrade:
- Campaigns (Business Component is Campaign)
- Campaign Plans (Business Component is DBM Campaign)
- Campaign Occurrences (Business Component is Campaign Occurrences)
If you customized the values for the Status field for these objects, convert the Status (S_SRC.STATUS_CD) of any existing records to the standard values before doing the upgrade. Any campaign records that do not have standard Status values will not create Load Wave records during the upgrade and will not be displayed as launched campaigns in the Campaign Agent views. Optionally, you can also migrate the status values for the following components:
- Program (Business Component is Program Container)
- Stage (Business Component is Program (DBM))
Table 19 lists the standard Status values for each object.
Table 19. Standard Status Values
Program Plan |
Planned Active Completed |
Stage Plan |
Campaign Plan |
Campaign |
Campaign Occurrence |
Pending Active Finished Manual Error Cancelled |
Table 20 lists search specifications for locating records containing Status values. Release 7.5 terminology is used for the object names.
Table 20. Search Specifications for Locating Records
Program Plan |
Program Container |
S_SRC
WHERE SUB_TYPE = 'MARKETING_CAMPAIGN' AND CAMP_TYPE_CD = 'PROGRAM CONTAINER' |
Stage Plan |
Program (DBM) |
S_SRC
WHERE SUB_TYPE = 'MARKETING_CAMPAIGN' AND CAMP_TYPE_CD = 'PROGRAM' |
Campaigns |
Campaign |
S_SRC
WHERE SUB_TYPE = 'MARKETING_CAMPAIGN' AND CAMP_TYPE_CD IS NULL AND CUST_TRGT_METH_CD IS NULL AND TMPL_ID IS NULL |
Campaign Plans |
DBM Campaign |
S_SRC
WHERE SUB_TYPE = 'MARKETING_CAMPAIGN' AND CAMP_TYPE_CD IS NULL AND CUST_TRGT_METH_CD IS NOT NULL |
Campaigns (Occurrences) |
Campaign Occurrences |
S_SRC
WHERE SUB_TYPE = 'MARKETING_CAMPAIGN' AND CAMP_TYPE_CD IS NULL AND CUST_TRGT_METH_CD IS NULL |
