Using Siebel Tools > About the Siebel Tools User Interface > About New Object WizardsVarious wizards in Siebel Tools step you through the process of creating objects. They prompt you for the required property values and configure any dependent object types. Wizards are available for many objects types, including:
You can access the New Object Wizards by choosing File > New Object. NOTE: Use the new object wizards to create objects whenever possible. For more information about using new object wizards, see Configuring Siebel Business Applications. |
| Using Siebel Tools |
