Using Siebel Tools > About the Siebel Tools User Interface >
About the Business Process Designer
The Siebel Business Process Designer allows you to define, manage, and enforce your company's business processes. Defining business processes is typically a development task. The Workflow Designer and the Workflow Simulator are integrated with Siebel Tools, allowing you to define and test business processes and related repository objects in a single environment. For more detailed information about creating business processes and using Workflow Designer and Workflow Simulator, see Siebel Business Process Designer Administration Guide.
