Using Siebel Tools > Working with Archive Files > Exporting Objects to an Archive File Using the Command-Line InterfaceYou can export objects using the command-line interface. You invoke the command-line interface from the siebdev executable, using the command switch The syntax of the siebdev.exe /c <config file> /d <database> /u <user name> /p <password> /batchexport <Repository Name> <Input File Name> <Log File> The command-line interface provided by the You can place multiple lines in the input file, each requesting to export multiple objects into different SIF file. However, if you specify the same SIF export file in multiple lines, only the last export takes effect—the previous exports will be overwritten. For example, consider the following sample text from an input file. Using this file as input, the switch "Business Component,*Account*,export.sif" NOTE: There must be no space before and after commas. The following sample export command would export objects specified in the input file, obj.txt. It also logs results into export.log: siebdev.exe /c tools.cfg /d sample /u sadmin /p sadmin /batchexport "siebel repository" obj.txt export.log |
| Using Siebel Tools |
