Using Siebel Tools > Customizing Your Siebel Tools Environment >
Defining Object List Editor Display Options
To define display options for the Object List Editor
- Choose View > Options.
The Development Tools Options dialog box appears.
- Click the List Views tab.
- Use the information in the following table to define your options.
List fonts |
Small/Normal/Large |
The size of the font used in the list. |
List spacing |
Tight/Normal/Loose |
The spacing between rows in the list. |
Style |
Horizontal grid lines |
Show or hide horizontal grid lines in the list. |
Vertical grid lines |
Show or hide vertical grid lines in the list. |
Alternating row color |
Use different colors for every second row. |
Mouse focus rectangle |
Show or hide dotted line that appears around the currently selected record. |
- Click OK.
