Using Siebel Tools > Customizing Your Siebel Tools Environment >
Showing and Hiding Toolbars
You show and hide toolbars using toggles on the View menu. To show or hide a toolbar
- Choose View > Toolbars. Alternatively, right-click any of the toolbars.
A list of toolbars appears in a secondary pop-up menu. A visible toolbar is identified with a check mark. A hidden toolbar has no marker.
- Select the toolbar you want to show or hide.
If the toolbar was hidden, it appears. If the toolbar was visible, it is hidden.
