Using Siebel Tools > Customizing Your Siebel Tools Environment > Setting Change Date PreferencesRecords are marked as changed in the Object List Editor when they occur after the date defined under the General Tab of the Development Tools Options dialog box. |
| Using Siebel Tools |
