Using Siebel Tools > Customizing Your Siebel Tools Environment > Process for Integrating with Third-Party Source ControlYou can integrate your repository check in/check out mechanism in Siebel Tools with a third-party source code-control system such as Microsoft Visual SourceSafe. When source control integration is enabled, each time a project is checked into the server repository, an archive file containing all the objects in the project is also checked into the source control system. As a result, successive versions of the project are maintained in the source control system. To integrate your repository check in/check out with a third-party source control system, perform the following tasks: |
Using Siebel Tools |
