Executable |
Enter the name of the Mobile Web Client executable (Siebel.exe). |
CFG file |
Enter the configuration file to be used by the client. |
Browser |
Enter the path to the browser executable. |
Working directory |
Enter the Siebel root directory (location of DLLs). |
Arguments |
Additional line options for starting the application. Common arguments are:
- /h - to enable local debugging of Server scripts
- /s <filename> - to enable SQL spooling
Prompt for this information each time |
Click this to display relevant information, such as executable, CFG file, browser, and so on, each time you run a debug operation. |
Show Workflow Primary Business Component Data |
If checked, the Watch Window in the Workflow Simulator will show all fields and their values from the primary Business Component of the Business Object associated with the Workflow process being simulated. |
User Name |
Enter the login of the user. |
Password |
Enter the password of the user name. |
Data source |
Enter the default data source. Values listed depend upon the configuration file specified in the CFG file parameter. |
