Using Siebel Tools > Siebel Script Editors > Using the Siebel Debugger >
Using the Siebel Calls Window
The Calls window contains a list of subroutine and function calls that were executed prior to the current line. To access the Calls window, click the Calls button in the Debugger toolbar when you are running the Debugger. A typical Calls window may contain several lines, one for each subroutine entered into and not yet completed. Selecting an entry in this list box causes the interpreter to shift to that entry. The Debugger window displays the line of code that made the call, and the Variable window displays the variables that are associated with the procedure that made the call.
