Using Siebel Tools > Siebel Script Editors > Using the Siebel Debugger > Invoking Compiler and Run-Time EngineTo invoke the Siebel Compiler and Run-time Engine, click the Compile button on the Debugger toolbar, or press F7. You can also invoke it when compiling a project containing object definitions with associated Siebel scripts. The Siebel Compiler and Run-time Engine has no user interface of its own. When the compiler is invoked, it compiles the custom routines and returns a message when completed that indicates success or failure. Compilation Order ConsiderationsThe Siebel Compiler compiles Siebel VB functions and procedures in alphabetical order within an object definition. If a function or procedure calls another function or procedure that has not been defined, the compiler generates an error message in the form: function_name Is An Unknown Function To avoid this error, use the Declare statement to declare the function or procedure in the (general) (declarations) section. For more information, read the VB Language Reference topics within Siebel VB Language Reference. Siebel eScript does not require forward declaration of functions. |
| Using Siebel Tools |
