Using Siebel Tools > Siebel Script Editors > About the ST eScript EngineThe Siebel ST eScript engine is compliant with ECMAScript Edition 4. ECMAScript is the standard implementation of JavaScript as defined by the ECMA -262 standard. The ST eScript engine, available in version 7.8 or higher, provides the following:
For a description of the functional differences in the scripting engines, as well as a description of Strong Typing syntax, see Siebel eScript Language Reference. To enable the ST eScript engine, perform the following procedure. To enable the ST eScript engine for Siebel Tools
NOTE: If you want to revert back to the T eScript engine after enabling the ST eScript engine and modifying your code to be strongly typed, you need to undo your strongly typed code changes. |
| Using Siebel Tools |
