Table 7. Error Numbers and Strings
5 |
Illegal function call |
6 |
Overflow |
7 |
Out of memory |
9 |
Subscript out of range |
10 |
Duplicate definition |
11 |
Division by zero |
13 |
Type Mismatch |
14 |
Out of string space |
19 |
No Resume |
20 |
Resume without error |
28 |
Out of stack space |
35 |
Sub or Function not defined |
48 |
Error in loading DLL |
52 |
Bad file name or number |
53 |
File not found |
54 |
Bad file mode |
55 |
File already open |
58 |
File already exists |
61 |
Disk full |
62 |
Input past end of file |
63 |
Bad record number |
64 |
Bad file name |
68 |
Device unavailable |
70 |
Permission denied |
71 |
Disk not ready |
74 |
Can't rename with different drive |
75 |
Path/File access error |
76 |
Path not found |
91 |
Object variable set to Nothing |
93 |
Invalid pattern |
94 |
Illegal use of NULL |
102 |
Command failed |
429 |
Object creation failed |
438 |
No such property or method |
439 |
Argument type mismatch |
440 |
Object error |
901 |
Input buffer would be larger than 64K |
902 |
Operating system error |
903 |
External procedure not found |
904 |
Global variable type mismatch |
905 |
User-defined type mismatch |
906 |
External procedure interface mismatch |
907 |
Pushbutton required |
908 |
Module has no MAIN |
910 |
Dialog box not declared |
