Siebel eSales Administration Guide > Shopping Service Methods Reference > Siebel eSales Workflow Methods >
SelectPrimary Method
This method is used to select a row from the picklist. Preconditions for Calling the SelectPrimary Method
None. Arguments for the SelectPrimary Method
The SelectPrimary method has the arguments shown in Table 44.
Table 44. SelectPrimary Arguments
PickList Field |
Input |
String |
Y |
Name of the field that has the picklist. |
Primary ID Field |
Input |
String |
Y |
Primary Id field. |
Primary Row Id |
Input |
String |
Y |
Row ID for the picklist. |
ReturnVal |
Output |
String |
Y |
Returns Success or Fail. Not used. |
Pseudo-Algorithm for SelectPrimary
- Get and check the input arguments.
- Get the picklist business component from the Quote business component with the PickList Field input argument.
- Set the search specification using either the Primary Row Id or Primary ID Field input argument.
- Pick the first row if an active row exists;
Else clear the picklist.
- Write and refresh the business component.
