Siebel eSales Administration Guide > Siebel eSales Workflow Reference > Siebel eSales Checkout Workflows >
eSales - Setting PO Status
The workflow for setting the status of a purchase order is shown in Figure 20.
Figure 20. eSales - Setting PO Status
When the eSales - Setting PO Status workflow is called by the eSales - Authorize Order Process (see Figure 15), the following events happen:
- The process determines whether the PO is pending.
- If it is, the order status is set to Awaiting Approval and the Send Order Awaiting Approval Email (eSales) process is called.
- If it is not, the process determines the user type.
- If the user is a power user, the Send Order Accepted Email (eSales) process (see Siebel eSales Notification Workflows) is called.
- If the user is of another type, the process determines whether the order amount is over the auto-approval limit.
- If it is not over the auto-approval limit, the Send Order Accepted Email (eSales) process is called.
- If it is over the limit, the order status is set to Awaiting Approval and the Send Order Awaiting Approval Email (eSales) process is called.
For more information about PO status, see Administering Siebel eSales.
