Siebel eSales Administration Guide > Siebel eSales Workflow Reference > Siebel eSales Order Modification Workflows >
eSales - Reorder Process
The workflow for reordering is shown in Figure 27. It works similarly to modifying an order.
Figure 27. eSales - Reorder Process
The eSales - Reorder Process is called when a customer clicks Reorder in the Order History Summary view. The following events happen:
- The process determines whether the Shopping Cart is empty.
- If it is empty, a new quote (Shopping Cart) is created from the order and the eSales - Checkout Process (see Figure 10) is called.
- If it is not empty, the Reorder Confirmation view appears, where the user has three choices:
