| Oracle® Retail Omnichannel Cloud Data Service Implementation Guide Release 19.0.000 F25864-02 |
![]() Previous |
![]() Next |
The OCDS (RIB) Injector is the interface between RIB infrastructure and OCDS; it listens for SOAP-based RIB messages for the families listed in the following table. The messages received by the OCDS Injector represent incremental changes to the merchandising data received in OCDS through BDI.
Table 4-1 RIB Families
| Family | Message Type |
Diffs |
DIFFCRE |
DIFFDEL |
DIFFMOD |
DiffGrp |
DIFFGRPHDRCRE |
DIFFGRPHDRMOD |
DIFFGRPDEL |
DIFFGRPDTLCRE |
DIFFGRPDTLDEL |
DIFFGRPDTLMOD |
ITEMLOC |
ITEMLOCCRE |
ITEMLOCMOD |
ITEMLOCDEL |
ITEMLOCREPLMOD |
Items |
ITEMIMAGECRE |
ITEMIMAGEDEL |
ITEMIMAGEMOD |
ITEMCRE |
ITEMDEL |
ITEMHDRMOD |
RELITEMHEADCRE |
RELITEMHEADMOD |
RELITEMHEADDEL |
RELITEMDETCRE |
RELITEMDETMOD |
RELITEMDETDEL |
ITEMVATCRE |
ITEMVATMOD |
ITEMVATDEL |
MERCHHIER |
CLASSCRE |
CLASSMOD |
CLASSDEL |
DEPTCRE |
DEPTMOD |
DEPTDEL |
DIVISIONCRE |
DIVISIONMOD |
DIVISIONDEL |
GROUPCRE |
GROUPMOD |
GROUPDEL |
SUBCLASSCRE |
SUBCLASSMOD |
SUBCLASSDEL |
ORGHIER |
ORGHIERCRE |
ORGHIERMOD |
ORGHIERDEL |
CHAINCRE |
CHAINMOD |
CHAINDEL |
AREACRE |
AREAMOD |
AREADEL |
REGIONCRE |
REGIONMOD |
REGIONDEL |
DISTRICTCRE |
DISTRICTMOD |
DISTRICTDEL |
STORES |
STORECRE |
STOREDEL |
STOREMOD |
STOREDTLCRE |
STOREDTLDEL |
STOREDTLMOD |
WH |
WHCRE |
WHDEL |
WHMOD |
WHDTLCRE |
WHDTLDEL |
WHDTLMOD |
The OCDS RIB Injector writes log messages to a log file on the file system under the deployment path for the injector.war. The log level is controlled by the ocds-injector.war\WEB-INF\lib\injector.jar\log4j.xml file.
WebLogic security realms provide a mechanism for protecting WebLogic resources. Users are entities that can be authenticated in a security realm. Users are organized into Groups that can have different levels of access to WebLogic resources.
This section lists the default security realm's Groups and Users used by the RIB Injector component.
A production OCDS should be integrated with IDCS or OIM. See the documentation for the integrated identity management solution for details on password management.
A non-production OCDS can simply use the WebLogic DefaultAuthenticator. The OCDS Injector's user password is authenticated by the default Authentication Provider configured for the security realm of the WebLogic domain. When using the DefaultAuthenticator, a user password can be reset directly by accessing the Users and Groups tab of the security realm's settings in the WebLogic Admin Console.
