| Oracle® Retail Omnichannel Cloud Data Service Implementation Guide Release 19.0.000 F25864-02 |
![]() Previous |
![]() Next |
BDI Job Admin is a web application and services responsible for management of the receiving of data into OCDS from BDI. In as much as BDI Job Admin is a component of OCDS, it is also a component of the enterprise infrastructure that enables OCDS to receive Merchandising and Pricing data.
OCDS (BDI) Job Admin is the interface between BDI infrastructure and OCDS, enabling BDI data to flow into the OCDS database. The following table lists the BDI Interfaces supported by OCDS for which data is exposed through REST web service resources.
Table 3-1 BDI Interfaces supported by OCDS
| Interface Module | BDI Type |
Clearance_Tx |
Transactional |
COFutureAvail_Tx |
Foundational |
DiffGrp_Fnd |
Foundational |
Diff_Fnd |
Foundational |
InvAvailStore_Tx |
Foundational |
InvAvailWh_Tx |
Foundational |
ItemHdr_Fnd |
Foundational |
ItemImage_Fnd |
Foundational |
ItemLoc_Fnd |
Foundational |
MerchHier_Fnd |
Foundational |
OrgHier_Fnd |
Foundational |
PriceChange_Tx |
Transactional |
PromotionOffer_TX |
Transactional |
RelatedItem_Fnd |
Foundational |
StoreAddr_Fnd |
Foundational |
Store_Fnd |
Foundational |
VatItem_Fnd |
Foundational |
Vat_Fnd |
Foundational |
WhAddr_Fnd |
Foundational |
Wh_Fnd |
Foundational |
OCDS receives data from two sources, BDI and RIB. For data families where RIB messages trickle incremental changes to OCDS, a one-time BDI job provides OCDS with an initial load. For data families without RIB support, scheduled BDI jobs provide OCDS with recurring refreshes.
Table 3-2 Recommended BDI Refreshes for OCDS
| BDI Family | BDI Refresh |
Clearance Price |
SCHEDULED |
Diff Group |
ONE-TIME ONLY |
Diff |
ONE-TIME ONLY |
Inv Avail Store |
SCHEDULED |
Inv Avail Warehouse |
SCHEDULED |
Inv Future Available |
SCHEDULED |
Item Header |
ONE-TIME ONLY |
Item Image |
ONE-TIME ONLY |
Item Location |
ONE-TIME ONLY |
Item Supplier |
ONE-TIME ONLY |
Merchandise Hierarchy |
ONE-TIME ONLY |
Organization Hierarchy |
ONE-TIME ONLY |
Price Change |
SCHEDULED |
Promotion |
SCHEDULED |
Related Item |
ONE-TIME ONLY |
Store |
ONE-TIME ONLY |
VAT |
SCHEDULED |
VAT Item |
ONE-TIME ONLY |
Warehouse |
ONE-TIME ONLY |
BDI families not utilizing RIB for incremental changes should be scheduled using the BDI Scheduler at intervals appropriate for the BDI family.
BDI families where initial load of data is provided by BDI, and incremental changes are provided by RIB, should not be scheduled using the BDI Scheduler. The only time OCDS should receive a subsequent BDI, after the initial load, is if the OCDS data is determined to be unreliable.
Important: Note that refreshing OCDS one-time only families may force downstream system, such as Xstore, to purge and completely refill all databases. Understanding how Omnichannel applications behave when OCDS is refreshed is extremely important when evaluating the decision to refresh "One-Time Only" data in OCDS from BDI.
WebLogic security realms provide a mechanism for protecting WebLogic resources. Users are entities that can be authenticated in a security realm. Users are organized into Groups that can have different levels of access to WebLogic resources.
This section lists the default security realm's Groups and Users used by the BDI Job Admin component.
See Monitoring Batch Jobs Using BDI Job Admin in Oracle® Retail Bulk Data Integration Implementation Guide for information about Job Admin User roles.
A production OCDS should be integrated with IDCS or OIM. See the documentation for the integrated identity management solution for details on password management.
A non-production OCDS can simply use the WebLogic DefaultAuthenticator. The OCDS JobAdmin's user password is authenticated by the default Authentication Provider configured for the security realm of the WebLogic domain. When using the DefaultAuthenticator, a user password can be reset directly by accessing the Users and Groups tab of the security realm's settings in the WebLogic Admin Console.
Job Admin logs to multiple files, all located on the file system under the deployment path for the ocds-batch-job-admin.war. For more information, see Monitoring Batch Jobs Using BDI Job Admin in Oracle® Retail Bulk Data Integration Implementation Guide for additional details regarding Job Admin logging.
The OCDS BDI Job Admin UI is a web application that provides the GUI for managing batch jobs and runtime.
The User Interface provides ability to:
Start/restart, and track status of jobs
Trace data
View diagnostic errors
Manage options at job and system level
View the logs
Job Admin is a standardized framework component used by Oracle Retail BDI Edge Applications. Detailed documentation for the component is available in the Oracle® Retail Bulk Data Integration Implementation Guide.
