| Oracle® Retail Omnichannel Cloud Data Service Installation Guide Release 19.1.000 F32768-04 |
![]() Previous |
![]() Next |
This chapter describes the procedure for installing and creating the WebLogic Middleware needed to host OCDS. Important information about the installation and deployment of a BDI Job Admin can be found in the Oracle Retail Bulk Data Integration Installation Guide.
For more information about installing WebLogic, see the Oracle Retail Bulk Data Integration Cloud Service Installation Guide.
The installation of OCDS Job Admin and Injector components requires the existence of schemas in a database prior to installation. These schemas are created and loaded in your database using the Repository Creation Utility (RCU).
For more information on how to create the required schema using the Repository Creation Utility, see the Oracle Retail Bulk Data Integration Cloud Service Installation Guide.
This section describes instructions for creating a new WebLogic domain with JRF, and instructions to create a managed server into which the OCDS Job Admin, Injector, and ORDS components can be deployed.
The installation of OCDS components requires the existence of schemas in a database prior to installation. These schemas are created and loaded in your database using the Repository Creation Utility (RCU). OCDS requires Oracle WebLogic server 12c (12.2.1.3.0), built with Java 8 (JDK 1.8 64 bit with the latest security updates).
The minimum recommended Java VM memory setting for the OCDS application domain is:
-Xms1024m -Xmx2048m
If re-creating a domain using the same RCU schemas, and those schemas are not in ocds_* tablespaces, then run RCU to drop old RCU schemas.
