Siebel Business Process Framework: Workflow Guide > Reference Materials for Siebel Workflow > Reference of Workflow Policy Object Properties > Properties of the Workflow Policy ProgramTable 124 describes properties displayed in the Workflow Policy Programs OBLE. About the DB Operation TypeOften, when some data changes, other data must be changed in accordance. This data dependency is frequently implemented at the Object Manager layer through business component definitions and run-time events. Database operations by workflow policies provide an alternative that works at the database record level. NOTE: It is recommended that DB Operation be used only when the data dependency involved centers around database records rather than around business components. For example, use DB operations when one database record must always be updated if another database record is inserted, regardless of which business components the two database records belong to, or whether the two database records belong to a business component at all. |
| Siebel Business Process Framework: Workflow Guide | Copyright © 2008, Oracle. All rights reserved. | |
