Siebel Business Process Framework: Workflow Guide > About Siebel Tools and Process Properties > About Process Properties > Referencing a Process PropertyA process property can be referenced from within an expression. The syntax is [&PropName]. For example: & indicates a process property, and Object Id is the name of the process property. The following example illustrates how a process property can be used as a substitution variable within a more complex expression. This example uses an input argument to establish a message body: The Activity #" + [&Object Id] + ", owned by " + [&First Name]+" "+[&Last Name] + " has passed three days from the Due Date. Where Object Id, First Name, and Last Name are defined as process properties. For more examples of using a process property as a substitution variable, see Example of Defining a Siebel Operation Search Specification and Substitution Variables Commonly Used in Expressions. |
| Siebel Business Process Framework: Workflow Guide | Copyright © 2008, Oracle. All rights reserved. | |
