Siebel Business Process Framework: Workflow Guide > About Siebel Tools and Process Properties >
About Process Properties
This topic provides information about process properties. It includes the following topics:
A process property is a container that stores values you can use in steps as input arguments, output arguments, or for performing evaluations. Process properties store values the workflow process retrieves from the database or derives before or during processing. You can base decision branches on the values in a process property and pass process properties as step arguments. When a workflow process finishes, the final result of the process properties are available as output arguments. You can also use process property values in expressions. For more about:
