Siebel Product Administration Guide > Siebel Configurator Rule Assembly Language >
Managing Constraints Written in Rule Assembly Language
Use the same procedures for copying, editing, and deleting constraints written in Rule Assembly Language that you use for constraints written using constraint templates. You can modify the Constraints list to display the RAL version of each constraint you create using constraint templates. This is a useful way to learn RAL and to understand more fully how constraint templates work. To modify the Constraints list, see Displaying RAL in the Constraints View.
