Siebel Product Administration Guide > Siebel Configurator Technical Reference >
Displaying RAL in the Constraints View
You can revise the Constraints list to add a field that displays the Rule Assembly Language (RAL) translation of your template rules. This is a useful way to learn how to use RAL to write configuration rules.
You must use Oracle's Siebel Tools to add the field to the Constraints record, and then recompile the siebel.srf file. You must be familiar with creating and modifying applets in Oracle's Siebel Tools before performing this procedure.
To revise the Constraints view, perform the following tasks:
  1. Locate the Constraints View Applet
  2. Modify the Constraints View Applet
  3. Recompile the Siebel.srf File
This task selects a target browser and queries for the Cfg SWE Rule Manager Applet.
To locate the Constraints View applet
  1. Save a copy of the siebel.srf file. It is located in the objects subdirectory of your installation directory.
  2. Start Oracle's Siebel Tools.
  3. Select View, Toolbars, Configuration Context.
  4. In the Target Browser Group drop-down menu, select Target Browser Config.
  5. In Available browser groups, select ALL and click the right-arrow to transfer it to "Selected browser groups for layout editing."
  6. Click OK.
  7. Click Applet in the Object Explorer.
  8. In the Applets list, query for the Cfg SWE Rule Manager Applet.
This task adds the Rule Spec field to the Cfg SWE Rule Manager Applet.
To modify the Constraints View applet
  1. With the SWE Rule Manager Applet highlighted, select Tools, Lock Project.
  2. Right click the highlighted applet record and select Edit Web Layout.
  3. In the window displaying the layout, right-click and select Preview from the pop-up menu.
  4. Click the Template icon and select the Applet List (Base/EditList) template. It is the default.
  5. In the Mode drop-down menu, select 3: Edit List.
  6. In the Controls/Columns window, click Rule Spec, and drag it to the [field] just to the right of End date in the applet display.
  7. Click Save. Click OK on the pop-up message that asks if you want to save your changes.
This task recompiles the application's siebel.srf file.
To recompile siebel.srf
  1. Click Tools, Compile.
  2. Select Locked Projects.
  3. Enter the path to the application siebel.srf file. It is located in the objects subdirectory of the installation. Do not enter the path to the siebel.srf file in the Tools installation directory.
Siebel Product Administration Guide Copyright © 2010, Oracle and/or its affiliates. All rights reserved. Legal Notices.
