Siebel Product Administration Guide > Siebel Configurator Rule Assembly Language > About Operators in Rule Assembly Language >
Data Operators in Rule Assembly Language
Use the following operators, shown in Table 28, when working with Siebel data types.
Table 28. Siebel Data Operators
Operator
Syntax
Properties
Number
Number(A)
Converts the operand to a number. Operand can be an expression.
String
String(A)
Converts the operand to a string. Operand can be an expression.
Date
Date(A)
Converts string to a date. Operand can be an expression.
Time
Time(A)
Converts the operand to a time. Operand can be an expression.
UtcDateTime
UtcDateTime(A)
Converts the operand to the UTC date and time. Operand can be an expression.
DateTime
DateTime(A)
Converts the operand to a date and time. Operand can be an expression. Not recommended for use. Use UtcDateTime instead.
Currency
Currency(A)
Converts the operand to currency. Operand can be an expression.
Phone
Phone(A)
Converts the operand to a phone number. Operand cannot be an expression. Can be used only with Equals (==) and Not Equal To (!=) operators to compare two phone numbers.
Siebel Product Administration Guide Copyright © 2010, Oracle and/or its affiliates. All rights reserved. Legal Notices.
