Siebel Product Administration Guide > Releasing Products and Other Versioned Objects > Migrating Products Among EnvironmentsSome businesses develop new versions of products in the same environment that they use for product that are already in production. Other businesses use separate environments for development and for production. If you use separate environments for development and production, you can migrate product data from the development to the production environment in either one of two ways:
NOTE: You cannot use EAI to import versioned data. Migrating Products Using Import and Export in Workspace Projects ViewUsing import and export in Workspace Projects view, you can migrate the versioned data that you can add to the Workspace Projects list, and you have the option of migrating related objects. When you export objects, a dialog box appears with these options:
In either case, all the objects are exported to a single XML file. When you import this XML file, they are imported as separate objects. The data that is exported depends on the value in the Testing Date field and Use Project flag of the Workspace Project header. If no base date is entered, it depends on the value in the Effective Start Date field. NOTE: To extend the import/export XML schema, extend integration objects under the project ISS VOD Import Export. To migrate product data using export and import in Workspace Projects view
Migrating Products Using Application Deployment Manager (ADM)You can also migrate products using Application Deployment Manager. You use the Joint WorkSpace content object to migrate key fields and versioned content for product itself, and you use the Product (ADM) content object to migrate the non-versioned content of product. If you are migrating non-standard fields, you must customize the Product (ADM) content object. For information about how to use ADM, see Siebel Application Deployment Manager Guide. |
| Siebel Product Administration Guide | Copyright © 2010, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
