Siebel Product Administration Guide > Configuration Constraint Template Reference > Require (Mutual) TemplateThe Require (Mutual) template has the following form: [Item or Condition] and [Item or Condition] mutually require each other Use this template when the required relationship between items or conditions is mutual. For example, Product A requires Product B, AND Product B requires When using components as the operands, you can specify global paths for either or both components. The Boolean equivalent of the Require (Mutual) template is NOT(A XOR B). Table 26 shows the truth table for this template. The behavior of the Require (Mutual) template is the same as the Exclude template, except that operands are required instead of excluded. |
| Siebel Product Administration Guide | Copyright © 2010, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
