Table 49. Parameters of the Transaction Processor Server Component
Clean DX Files Iterations |
CleanFilesIter |
Optional |
Frequency for the Transaction Processor server component to delete DX files from the docking\txnproc directory of the Siebel Server. The default value is 1 iteration, with a default of 60 seconds for each iteration, as set in the SleepTime parameter. |
Clean Transaction Iterations |
CleanTxnsIter |
Optional |
Frequency for the Transaction Processor server component to delete transactions from the master transaction log table of the server database. You specify this parameter as the number of iterations. The default value is 10. |
Maximum Reads per Iteration |
MaxRead |
Optional |
Maximum number of operations to read for each iteration. The default value is 0, which means the Transaction Processor server component reads outstanding operations in the Master Transaction Log. |
Sleep Time |
SleepTime |
Optional |
Time, in seconds, to sleep between iterations. When the Transaction Processor server component wakes up, it processes transactions. The default value is 60. |
TS Block Size |
TSBlockSize |
Optional |
Block size for dobjinst.dbf, which is the visibility database, in bytes. The Transaction Processor server component stores data in blocks. This block size is different from the block size that the operating system uses. The default value is 4096 bytes. For help with changing this parameter, see Getting Help from Oracle. |
TS Cache Size |
TSCacheSize |
Optional |
Cache size for dobjinst.dbf, which is the visibility database, in kilobytes. The default value is 4096 kilobytes. For help with changing this parameter, see Getting Help from Oracle. |
Write Compressed DX Files |
WriteCompressed |
Optional |
Writes DX files in compressed format. The default value is FALSE. Leave this parameter at the default value. For help with changing this parameter, see Getting Help from Oracle. |
