Table 27. Columns Denormalized During Upgrades from Release 6.3 Siebel Industry Solutions
S_ACCNT_POSTN
ACCNT_TYPE_CD
[OU_EXT_ID].[ACCNT_TYPE_CD] |
S_ORG_EXT
ACCNT_TYPE_CD
S_ACCNT_POSTN
CLIENT_FLG
[OU_EXT_ID].[CLIENT_FLG] |
S_ORG_EXT
CLIENT_FLG
S_ACCNT_POSTN
FACILITY_FLG
[OU_EXT_ID].[FACILITY_FLG] |
S_ORG_EXT
FACILITY_FLG
S_ACCNT_POSTN
INVSTR_FLG
[OU_EXT_ID].[INVSTR_FLG] |
S_ORG_EXT
INVSTR_FLG
S_ACCNT_POSTN
ORG_REF_CUST_ FLG
[OU_EXT_ID].[REFERENCE_CUST_FLG] |
S_ORG_EXT
REFERENCE_CUST_FLG
S_ACCNT_POSTN
SRV_PROVDR_FLG
[OU_EXT_ID].[SRV_PROVDR_FLG] |
S_ORG_EXT
SRV_PROVDR_FLG
S_ACT_CAL_RSRC
ACT_APPT_REPT_ FLG
[ACTIVITY_ID].[APPT_REPT_FLG] |
S_EVT_ACT
APPT_REPT_FLG
S_ACT_CAL_RSRC
ACT_APPT_RPTEND_DT
[ACTIVITY_ID].[APPT_REPT_END_DT] |
S_EVT_ACT
APPT_REPT_END_ DT
S_ACT_CAL_RSRC
ACT_CAL_TYPE_CD
[ACTIVITY_ID].[CAL_TYPE_CD] |
S_EVT_ACT
CAL_TYPE_CD
S_ACT_CAL_RSRC
ACT_TEMPLATE_ FLG
[ACTIVITY_ID].[TEMPLATE_FLG] |
S_EVT_ACT
TEMPLATE_FLG
S_ACT_CAL_RSRC
ACT_TODO_PLNEND_DT
[ACTIVITY_ID].[TODO_PLAN_END_DT] |
S_EVT_ACT
TODO_PLAN_END_ DT
S_ACT_CAL_RSRC
ACT_TODO_ PLNSTRTDT
[ACTIVITY_ID].[TODO_PLAN_START_DT] |
S_EVT_ACT
TODO_PLAN_START_DT
S_ACT_EMP
ACT_ALARM_FLG
[ACTIVITY_ID].[ALARM_FLAG] |
S_EVT_ACT
ALARM_FLAG
S_ACT_EMP
ACT_APPT_REPT_ FLG
S_EVT_ACT
APPT_REPT_FLG
S_ACT_EMP
ACT_APPT_RPTEND_DT
S_EVT_ACT
APPT_REPT_END_ DT
S_ACT_EMP
ACT_APPT_START_DT
[ACTIVITY_ID].[APPT_START_DT] |
S_EVT_ACT
APPT_START_DT
S_ACT_EMP
ACT_CAL_DISP_ FLG
[ACTIVITY_ID].[CAL_DISP_FLG] |
S_EVT_ACT
CAL_DISP_FLG
S_ACT_EMP
ACT_CAL_TYPE_CD
S_EVT_ACT
CAL_TYPE_CD
S_ACT_EMP
ACT_EVT_STAT_CD
[ACTIVITY_ID].[EVT_STAT_CD] |
S_EVT_ACT
EVT_STAT_CD
S_ACT_EMP
ACT_TEMPLATE_ FLG
S_EVT_ACT
TEMPLATE_FLG
S_ACT_EMP
ACT_TODO_ PLNEND_DT
S_EVT_ACT
TODO_PLAN_END_ DT
S_ACT_EMP
ACT_TODO_ PLNSTRTDT
S_EVT_ACT
TODO_PLAN_START_DT
S_AGREE_POSTN
AGREE_NAME
[AGREE_ID].[NAME] |
S_DOC_AGREE
NAME
S_AGREE_POSTN
AGREE_STAT_CD
[AGREE_ID].[STAT_CD] |
S_DOC_AGREE
STAT_CD
S_AGREE_POSTN
AGREE_VALID_FLG
[AGREE_ID].[VALID_FLG] |
S_DOC_AGREE
VALID_FLG
S_ASSET_BU
ASSET_NUM
[ASSET_ID].[ASSET_NUM] |
S_ASSET
ASSET_NUM
S_ASSET_BU
TYPE_CD
[ASSET_ID].[TYPE_CD] |
S_ASSET
TYPE_CD
S_ASSET_POSTN
ASSET_NUM
S_ASSET
ASSET_NUM
S_ASSET_POSTN
TYPE_CD
S_ASSET
TYPE_CD
S_CASE_BU
CASE_NAME
[CASE_ID].[NAME] |
S_CASE
NAME
S_CASE_BU
CASE_STATUS_CD
[CASE_ID].[STATUS_CD] |
S_CASE
STATUS_CD
S_CASE_BU
CASE_TYPE_CD
[CASE_ID].[TYPE_CD] |
S_CASE
TYPE_CD
S_CONTACT_BU
AGENT_FLG
[CONTACT_ID].[AGENT_FLG] |
S_CONTACT
AGENT_FLG
S_CONTACT_BU
CON_EMP_FLG
[CONTACT_ID].[EMP_FLG] |
S_CONTACT
EMP_FLG
S_CONTACT_BU
CON_FST_NAME
[CONTACT_ID].[FST_NAME] |
S_CONTACT
FST_NAME
S_CONTACT_BU
CON_LAST_NAME
[CONTACT_ID].[LAST_NAME] |
S_CONTACT
LAST_NAME
S_CONTACT_BU
CON_MID_NAME
[CONTACT_ID].[MID_NAME] |
S_CONTACT
MID_NAME
S_CONTACT_BU
MEMBER_FLG
[CONTACT_ID].[MEMBER_FLG] |
S_CONTACT
MEMBER_FLG
S_CONTACT_BU
PROVIDER_FLG
[CONTACT_ID].[PROVIDER_FLG] |
S_CONTACT
PROVIDER_FLG
S_CTLG_CAT_AUC
AUC_AUC_LOT_NUM
[AUC_ITEM_ID].[AUC_LOT_NUM] |
S_AUC_ITEM
AUC_LOT_NUM
S_CTLG_CAT_ CRSE
CRSE_NAME
[CRSE_ID].[NAME] |
S_CRSE
NAME
S_CTLG_CAT_ CRSE
CRSE_SUB_TYPE
[CRSE_ID].[SUB_TYPE] |
S_CRSE
SUB_TYPE
S_CTLG_CAT_ DFCT
DFCT_DFCT_NUM
[PROD_DEFECT_ID].[DEFECT_NUM] |
S_PROD_DEFECT
DEFECT_NUM
S_CTLG_CAT_ISS
ISS_NAME
[ISS_ID].[NAME] |
S_ISS
NAME
S_CTLG_CAT_LIT
LIT_NAME
[LIT_ID].[NAME] |
S_LIT
NAME
S_CTLG_CAT_ORG
ORG_CMPT_FLG
[ORG_ID].[CMPT_ FLG] |
S_ORG_EXT
CMPT_FLG
S_CTLG_CAT_ORG
ORG_LOC
[ORG_ID].[LOC] |
S_ORG_EXT
LOC
S_CTLG_CAT_ORG
ORG_NAME
[ORG_ID].[NAME] |
S_ORG_EXT
NAME
S_CTLG_CAT_ORG
ORG_PRTNR_FLG
[ORG_ID].[PRTNR_ FLG] |
S_ORG_EXT
PRTNR_FLG
S_CTLG_CAT_ PROD
PROD_EFF_END_DT
[PROD_ID].[EFF_ END_DT] |
S_PROD_INT
EFF_END_DT
S_CTLG_CAT_ PROD
PROD_EFF_START_DT
[PROD_ID].[EFF_START_DT] |
S_PROD_INT
EFF_START_DT
S_CTLG_CAT_ PROD
PROD_NAME
[PROD_ID].[NAME] |
S_PROD_INT
NAME
S_CTLG_CAT_SR
SR_SR_NUM
[SRV_REQ_ID].[SR_NUM] |
S_SRV_REQ
SR_NUM
S_CTLG_CAT_SRC
SRC_NAME
[SRC_ID].[NAME] |
S_SRC
NAME
S_CTLG_CAT_SRC
SRC_SRC_NUM
[SRC_ID].[SRC_NUM] |
S_SRC
SRC_NUM
S_CTLG_CAT_SRC
SRC_SUB_TYPE
[SRC_ID].[SUB_ TYPE] |
S_SRC
SUB_TYPE
S_CTLGCAT_ ASSET
ASSET_ASSET_NUM
S_ASSET
ASSET_NUM
S_CTLGCAT_ ASSET
ASSET_SERIAL_ NUM
[ASSET_ID].[SERIAL_NUM] |
S_ASSET
SERIAL_NUM
S_CTLGCAT_PATH
CS_PATH_NAME
[CS_PATH_ID]. [NAME] |
S_CS_PATH
NAME
S_CTLGCT_ RESITM
RI_INTR_PUBL_ FLG
[RES_ITEM_ID].[ INTR_PUBLISH_FLG] |
S_RES_ITEM
INTR_PUBLISH_ FLG
S_CTLGCT_ RESITM
RI_NAME
[RES_ITEM_ID]. [NAME] |
S_RES_ITEM
NAME
S_CTLGCT_ RESITM
RI_TYPE_CD
[RES_ITEM_ID]. [TYPE_CD] |
S_RES_ITEM
TYPE_CD
S_DOC_AGREE_BU
AGREE_NAME
[AGREEMENT_ID]. [NAME] |
S_DOC_AGREE
NAME
S_DOC_AGREE_BU
AGREE_STAT_CD
[AGREEMENT_ID]. [STAT_CD] |
S_DOC_AGREE
STAT_CD
S_DOC_AGREE_BU
AGREE_VALID_FLG
[AGREEMENT_ID]. [VALID_FLG] |
S_DOC_AGREE
VALID_FLG
S_DOC_PPSL_BU
PPSL_DFLT_TMPL_FLG
[DOC_PPSL_ID].[DFLT_TEMPLATE_FLG] |
S_DOC_PPSL
DFLT_TEMPLATE_ FLG
S_DOC_PPSL_BU
PPSL_NAME
[DOC_PPSL_ID]. [NAME] |
S_DOC_PPSL
NAME
S_DOC_PPSL_BU
PPSL_TEMPLATE_ FLG
[DOC_PPSL_ID]. [TEMPLATE_FLG] |
S_DOC_PPSL
TEMPLATE_FLG
S_DOC_PPSL_BU
PPSL_TYPE_CD
[DOC_PPSL_ID]. [PPSL_TYPE_CD] |
S_DOC_PPSL
PPSL_TYPE_CD
S_DOC_QUOTE_BU
DOC_QTE_NUM
[DOC_QUOTE_ID]. [QUOTE_NUM] |
S_DOC_QUOTE
QUOTE_NUM
S_DOC_QUOTE_BU
DOC_QTE_REV_NUM
[DOC_QUOTE_ID]. [REV_NUM] |
S_DOC_QUOTE
REV_NUM
S_DOC_QUOTE_BU
DOC_QUOTE_NAME
[DOC_QUOTE_ID]. [NAME] |
S_DOC_QUOTE
NAME
S_INSCLM_BU
INSCLAIM_NUM
[INSCLM_ID]. [INSCLAIM_NUM] |
S_INS_CLAIM
INSCLAIM_NUM
S_INSCLM_BU
REV_NUM
[INSCLM_ID]. [REVISION_NUM] |
S_INS_CLAIM
REVISION_NUM
S_INSCLMEL_BU
SEQ_NUM
[INSCLM_ELMNT_ ID].[SEQ_NUM] |
S_INSCLM_ ELMNT
SEQ_NUM
S_INSCLMEL_BU
TYPE_CD
[INSCLM_ELMNT_ ID].[TYPE_CD] |
S_INSCLM_ ELMNT
TYPE_CD
S_INV_TXN_BU
INV_TXN_NUM
[INV_TXN_ID]. [INV_TXN_NUM] |
S_INV_TXN
INV_TXN_NUM
S_ISS_BU
ISS_LANG_ID
[ISS_ID].[LANG_ID] |
S_ISS
LANG_ID
S_ISS_BU
ISS_NAME
[ISS_ID].[NAME] |
S_ISS
NAME
S_LOY_MEM_BU
MEM_NUM
[MEMBER_ID]. [MEM_NUM] |
S_LOY_MEMBER
MEM_NUM
S_LOY_MEM_BU
MEM_TYPE_CD
[MEMBER_ID]. [MEM_TYPE_CD] |
S_LOY_MEMBER
MEM_TYPE_CD
S_LOY_MEM_PSTN
MEM_NUM
S_LOY_MEMBER
MEM_NUM
S_LOY_MEM_PSTN
MEM_TYPE_CD
S_LOY_MEMBER
MEM_TYPE_CD
S_LOY_PROG_BU
PROG_NAME
[PROG_ID].[NAME] |
S_LOY_PROG
NAME
S_LOY_PROMO_BU
PROMO_NAME
[PROMO_ID]. [NAME] |
S_LOY_PROMO
NAME
S_LOY_PROMO_BU
PROMO_NUM
[PROMO_ID]. [PROMO_NUM] |
S_LOY_PROMO
PROMO_NUM
S_LOY_TXN_BU
TXN_NUM
[TXN_ID].[TXN_ NUM] |
S_LOY_TXN
TXN_NUM
S_LOY_TXN_BU
TXN_STATUS_CD
[TXN_ID].[STATUS_CD] |
S_LOY_TXN
STATUS_CD
S_LOY_TXN_BU
TXN_SUB_TYPE_CD
[TXN_ID].[SUB_ TYPE_CD] |
S_LOY_TXN
SUB_TYPE_CD
S_LOY_TXN_BU
TXN_TYPE_CD
[TXN_ID].[TYPE_ CD] |
S_LOY_TXN
TYPE_CD
S_MDF_BU
MDF_UID
[MDF_ID].[MDF_ UID] |
S_MDF
MDF_UID
S_OPTY_BU
OPTY_NAME
[OPTY_ID].[NAME] |
S_OPTY
NAME
S_OPTY_BU
SUM_CLASS_CD
[OPTY_ID].[SUM_ CLASS_CD] |
S_OPTY
SUM_CLASS_CD
S_OPTY_BU
SUM_COMMIT_FLG
[OPTY_ID].[SUM_ COMMIT_FLG] |
S_OPTY
SUM_COMMIT_FLG
S_OPTY_BU
SUM_COST_AMT
[OPTY_ID].[SUM_ COST_AMT] |
S_OPTY
SUM_COST_AMT
S_OPTY_BU
SUM_DOWNSIDE_ AMT
[OPTY_ID].[SUM_ DOWNSIDE_AMT] |
S_OPTY
SUM_DOWNSIDE_ AMT
S_OPTY_BU
SUM_EFFECTIVE_ DT
[OPTY_ID].[SUM_ EFFECTIVE_DT] |
S_OPTY
SUM_EFFECTIVE_ DT
S_OPTY_BU
SUM_MARGIN_AMT
[OPTY_ID].[SUM_ MARGIN_AMT] |
S_OPTY
SUM_MARGIN_AMT
S_OPTY_BU
SUM_REVN_AMT
[OPTY_ID].[SUM_ REVN_AMT] |
S_OPTY
SUM_REVN_AMT
S_OPTY_BU
SUM_TYPE_CD
[OPTY_ID].[SUM_ TYPE_CD] |
S_OPTY
SUM_TYPE_CD
S_OPTY_BU
SUM_UPSIDE_AMT
[OPTY_ID].[SUM_ UPSIDE_AMT] |
S_OPTY
SUM_UPSIDE_AMT
S_OPTY_BU
SUM_WIN_PROB
[OPTY_ID].[SUM_ WIN_PROB] |
S_OPTY
SUM_WIN_PROB
S_OPTY_POSTN
CONSUMER_OPTY_ FLG
[OPTY_ID].[CONSUMER_OPTY_FLG] |
S_OPTY
CONSUMER_OPTY_ FLG
S_OPTY_POSTN
NEW_LOAN_FLG
[OPTY_ID].[NEW_ LOAN_FLG] |
S_OPTY
NEW_LOAN_FLG
S_OPTY_POSTN
OPTY_CLOSED_FLG
[OPTY_ID].[CLOSED_FLG] |
S_OPTY
CLOSED_FLG
S_OPTY_POSTN
OPTY_NAME
[OPTY_ID].[NAME] |
S_OPTY
NAME
S_OPTY_POSTN
SECURE_FLG
[OPTY_ID].[SECURE_FLG] |
S_OPTY
SECURE_FLG
S_OPTY_POSTN
SUM_CLASS_CD
S_OPTY
SUM_CLASS_CD
S_OPTY_POSTN
SUM_COMMIT_FLG
S_OPTY
SUM_COMMIT_FLG
S_OPTY_POSTN
SUM_COST_AMT
S_OPTY
SUM_COST_AMT
S_OPTY_POSTN
SUM_DOWNSIDE_ AMT
S_OPTY
SUM_DOWNSIDE_ AMT
S_OPTY_POSTN
SUM_EFFECTIVE_ DT
S_OPTY
SUM_EFFECTIVE_ DT
S_OPTY_POSTN
SUM_MARGIN_AMT
S_OPTY
SUM_MARGIN_AMT
S_OPTY_POSTN
SUM_REVN_AMT
S_OPTY
SUM_REVN_AMT
S_OPTY_POSTN
SUM_TYPE_CD
S_OPTY
SUM_TYPE_CD
S_OPTY_POSTN
SUM_UPSIDE_AMT
[OPTY_ID].[SUM_UPSIDE_AMT] |
S_OPTY
SUM_UPSIDE_AMT
S_OPTY_POSTN
SUM_WIN_PROB
S_OPTY
SUM_WIN_PROB
S_ORDER_BU
ORDER_CAT_CD
[ORDER_ID]. [ORDER_CAT_CD] |
S_ORDER
ORDER_CAT_CD
S_ORDER_BU
ORDER_DT
[ORDER_ID]. [ORDER_DT] |
S_ORDER
ORDER_DT
S_ORDER_BU
ORDER_NUM
[ORDER_ID]. [ORDER_NUM] |
S_ORDER
ORDER_NUM
S_ORDER_POSTN
ORDER_CAT_CD
S_ORDER
ORDER_CAT_CD
S_ORDER_POSTN
ORDER_DT
S_ORDER
ORDER_DT
S_ORDER_POSTN
ORDER_NUM
S_ORDER
ORDER_NUM
S_ORG_BU
ORG_CMPT_FLG
S_ORG_EXT
CMPT_FLG
S_ORG_BU
ORG_FACILITY_ FLG
[ORG_ID].[FACILITY_FLG] |
S_ORG_EXT
FACILITY_FLG
S_ORG_BU
ORG_INVSTR_FLG
[ORG_ID].[INVSTR_FLG] |
S_ORG_EXT
INVSTR_FLG
S_ORG_BU
ORG_LOC
[ORG_ID].[LOC] |
S_ORG_EXT
LOC
S_ORG_BU
ORG_NAME
[ORG_ID].[NAME] |
S_ORG_EXT
NAME
S_ORG_BU
ORG_PRTNR_FLG
S_ORG_EXT
PRTNR_FLG
S_ORG_BU
ORG_REF_CUST_ FLG
[ORG_ID].[REFERENCE_CUST_FLG] |
S_ORG_EXT
REFERENCE_CUST_FLG
S_ORG_BU
ORG_SRV_PROVDR_FLG
[ORG_ID].[SRV_ PROVDR_FLG] |
S_ORG_EXT
SRV_PROVDR_FLG
S_ORG_DIST_LST
OU_ID
[ORG_PROD_ID]. [OU_ID] |
S_ORG_PROD
OU_ID
S_ORG_GROUP_BU
OG_GROUP_NAME
[ORG_GROUP_ID]. [GROUP_NAME] |
S_ORG_GROUP
GROUP_NAME
S_ORG_GROUP_BU
OG_GROUP_TYPE_ CD
[ORG_GROUP_ID]. [GROUP_TYPE_CD] |
S_ORG_GROUP
GROUP_TYPE_CD
S_ORG_GROUP_BU
OG_NAME
[ORG_GROUP_ID]. [NAME] |
S_ORG_GROUP
NAME
S_ORGGRP_POSTN
GROUP_TYPE_CD
[ORGGRP_ID].[GROUP_TYPE_CD] |
S_ORG_GROUP
GROUP_TYPE_CD
S_ORGGRP_POSTN
GRP_GROUP_NAME
[ORGGRP_ID]. [GROUP_NAME] |
S_ORG_GROUP
GROUP_NAME
S_ORGGRP_POSTN
GRP_NAME
[ORGGRP_ID]. [NAME] |
S_ORG_GROUP
NAME
S_PARTY_GRP_BU
PG_NAME
[PARTY_GROUP_ID].[NAME] |
S_PARTY_GROUP
NAME
S_PERIOD_BU
PERIOD_NAME
[PERIOD_ID]. [NAME] |
S_PERIOD
NAME
S_POS_BU
POS_NUM
[POS_ID].[POS_ NUM] |
S_POS
POS_NUM
S_POSTN_CON
AGENT_FLG
[CON_ID].[AGENT_ FLG] |
S_CONTACT
AGENT_FLG
S_POSTN_CON
MEMBER_FLG
[CON_ID].[MEMBER_FLG] |
S_CONTACT
MEMBER_FLG
S_POSTN_CON
PROVIDER_FLG
[CON_ID]. [PROVIDER_FLG] |
S_CONTACT
PROVIDER_FLG
S_PRIFCTR_ITM
PRIMDL_ID
[PRIMDL_FCTR_ID].[PRIMDL_ID] |
S_PRIMDL_FCTR
PRIMDL_ID
S_PROD_DFCT_BU
DEFECT_NUM
S_PROD_DEFECT
DEFECT_NUM
S_PROD_INT_BU
PROD_CD
[PROD_INT_ID]. [PROD_CD] |
S_PROD_INT
PROD_CD
S_PROD_INT_BU
PROD_EFF_END_DT
[PROD_INT_ID]. [EFF_END_DT] |
S_PROD_INT
EFF_END_DT
S_PROD_INT_BU
PROD_EFF_START_DT
[PROD_INT_ID]. [EFF_START_DT] |
S_PROD_INT
EFF_START_DT
S_PROD_STYL_ TNT
SETUP_STYLE_CD
[PROP_STYLE_ID]. [SETUP_STYLE_CD] |
S_PROP_STYL_ TNT
SETUP_STYLE_CD
S_PROJ_BU
PROJ_NAME
[PROJ_ID].[NAME] |
S_PROJ
NAME
S_PROJ_BU
PROJ_STATUS_CD
[PROJ_ID].[STATUS_CD] |
S_PROJ
STATUS_CD
S_PROJ_BU
PROJ_TYPE_CD
[PROJ_ID].[PROJ_ TYPE_CD] |
S_PROJ
PROJ_TYPE_CD
S_PSP_PROC_BU
VOD_NAME
[VOD_ID].[VOD_NAME] |
S_VOD
VOD_NAME
S_QUOTE_POSTN
QUOTE_NUM
[QUOTE_ID]. [QUOTE_NUM] |
S_DOC_QUOTE
QUOTE_NUM
S_SALES_MTHD_ BU
SALES_METHOD_ NAME
[SALES_METHOD_ ID].[NAME] |
S_SALES_ METHOD
NAME
S_SRC_BU
SRC_NAME
[SRC_ID].[NAME] |
S_SRC
NAME
S_SRV_REQ_BU
SR_AREA
[SRV_REQ_ID].[SR_AREA] |
S_SRV_REQ
SR_AREA
S_SRV_REQ_BU
SR_CST_NUM
[SRV_REQ_ID].[SR_CST_NUM] |
S_SRV_REQ
SR_CST_NUM
S_SRV_REQ_BU
SR_NUM
S_SRV_REQ
SR_NUM
S_SRV_REQ_BU
SR_SEV_CD
[SRV_REQ_ID].[SR_SEV_CD] |
S_SRV_REQ
SR_SEV_CD
S_SRV_REQ_BU
SR_STAT_ID
[SRV_REQ_ID].[SR_STAT_ID] |
S_SRV_REQ
SR_STAT_ID
S_SRV_REQ_BU
SR_SUB_STAT_ID
[SRV_REQ_ID].[SR_SUB_STAT_ID] |
S_SRV_REQ
SR_SUB_STAT_ID
S_SRV_REQ_BU
SR_TITLE
[SRV_REQ_ID].[SR_TITLE] |
S_SRV_REQ
SR_TITLE
S_SRV_REQ_BU
SR_TYPE_CD
[SRV_REQ_ID].[SR_TYPE_CD] |
S_SRV_REQ
SR_TYPE_CD
S_TMPL_PLNIT_ BU
PLANITEM_NAME
[TMPL_PLANITEM_ ID].[NAME] |
S_TMPL_ PLANITEM
NAME
S_TMPL_PLNIT_ BU
PLANITEM_TYPE_ CD
[TMPL_PLANITEM_ ID].[TYPE_CD] |
S_TMPL_ PLANITEM
TYPE_CD
S_TMPL_PLNIT_ BU
PLNIT_TMPL_TYPE_CD
[TMPL_PLANITEM_ID].[TMPL_TYPE_CD] |
S_TMPL_ PLANITEM
TMPL_TYPE_CD
S_USERLIST_BU
UL_NAME
[USERLIST_ID]. [NAME] |
S_USERLIST
NAME
S_WRNTY_CVRG_ BU
WRNTY_CVRG_NAME
[WRNTY_CVRG_ID].[WRNTY_NAME] |
S_WRNTY_CVRG
WRNTY_NAME
T_MASTER_BU
MASTER_ALIAS
[MASTER_ID]. [ALIAS] |
T_MASTER
ALIAS
T_MASTER_BU
MASTER_NAME
[MASTER_ID]. [NAME] |
T_MASTER
NAME
T_MASTER_ DETAIL
DETAIL_SX2_NAME
[DETAIL_SX2_ID]. [SX2_NAME] |
T_DETAIL_SX2
SX2_NAME
T_MASTER_ DETAIL
MASTER_NAME
T_MASTER
NAME
T_MASTER_PER
MASTER_ALIAS
T_MASTER
ALIAS
T_MASTER_POSTN
MASTER_NAME
T_MASTER
NAME
