Siebel Database Upgrade Guide for DB2 UDB for z/OS > Reviewing the Siebel Upgrade Log Files > Manually Archiving Upgrade Log FilesEnvironments: All environments. This topic is part of an upgrade process. See How to Perform a Siebel Database Upgrade. After a successful installation and upgrade, you must manually save and archive the log files located in the By default, only nine (9) upgrade log files are retained for subsequent retries of the Siebel Upgrade Wizard. After nine log files have been created, when the Siebel Upgrade Wizard is rerun, it overwrites log files beginning with the earliest one created and recycles the rest as necessary. (This does not apply to the state.log file.) The number of log files retained can be increased by resetting the siebel_log_archive environment variable to 20—for example, to retain twenty (20) log files. |
| Siebel Database Upgrade Guide for DB2 UDB for z/OS | Copyright © 2012, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
