Siebel Database Upgrade Guide for DB2 UDB for z/OS > Reviewing the Siebel Upgrade Log Files > Running SQL in Siebel LogsBy using SPUFI or the command line, you can construct SQL queries to run against the staging or the target log tables. The following statements report the status of the load jobs for the staging or target databases:
This following statement checks for failed unload jobs, but can check for any other job by changing the JOB_NAME LIKE statement to use the appropriate prefix.
| Siebel Database Upgrade Guide for DB2 UDB for z/OS | Copyright © 2012, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
