Siebel Database Upgrade Guide for DB2 UDB for z/OS > Generating the Siebel Upgrade Files >
Prerequisite Tasks for Generating the Upgrade Files
Upgrades: All upgrades. Environments: All environments. Complete the following tasks before starting to generate the upgrade files:
- Extract the storage layout of the Siebel staging database from the DB2 catalog and merge it with a Siebel 8.0 storage control file so as to preserve any customizations you have made to the database layout in the upgraded database. To do this, run the Database Configuration Wizard and select the Extract from Catalog and Merge with Template option.
For further information on this task, see Extracting the Storage Control File.
- Validate the merged storage control file generated in Step 1 against the staging database. For information on this task, see Validating the Extracted Storage Control File. If there are validation errors, you must correct them before proceeding with the upgrade.
