Siebel Database Upgrade Guide for DB2 UDB for z/OS > Migrating Siebel 6.2.1 Customizations > Regenerating the Postmerge Utilities LogEnvironments: Development environment only. This topic is part of an upgrade process. See How to Perform a Siebel Database Upgrade. When upgrading from Release 6.2.1 to Release 8.0, you perform the repository merge and then the Siebel Web Client migration. This invalidates part of the postmerge utilities log created after the repository merge. You must regenerate the postmerge utilities log before using it to evaluate the merge. After the repository merge, the postmerge utilities start automatically. They help resolve common repository merge problems related to configuration and layout. These utilities write to the postmerge utilities log:
Requirements: You must have run the repository merge and the Siebel Web Client Migration Wizard. |
| Siebel Database Upgrade Guide for DB2 UDB for z/OS | Copyright © 2012, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
