Siebel Database Upgrade Guide for DB2 UDB for z/OS > Migrating Siebel 6.2.1 Customizations > Reviewing Customized Business ComponentsEnvironments: Development environment only. This topic is part of an upgrade process. See How to Perform a Siebel Database Upgrade. After upgrading the Siebel database to Release 8.0, thoroughly review the postupgrade configuration to make sure that the object level definitions are preserved as expected. The access control business component migration utility, upgcust, is run on the Prior Customer Repository by the Upgrade Wizard during upgrade of the Siebel database schema. This utility reconfigures custom business component configurations on obsolete tables. However, you may need to perform manual steps to business component fields and joins, depending upon the complexity of your business component configuration. In some cases, not all custom business components are reconfigured by the access control business component migration utility. For example, customer business components that are based on customer extension columns or on Siebel columns in obsolete tables need to be identified and manually fixed after the upgrade. During the upgrade, the access control business component migration utility, upgcust, generates a log file titled Log File Part 1For extension columns on obsolete tables such as The report generated by part 1 of the log file provides a list of the business component fields that are based on custom extension columns in obsolete tables such as Upgrades from Release 7.0.x and 7.5.xThe table Log File Part 2After the repository merge has been run, there may be inconsistencies in the join names and joins set at the field level due to merge behavior. If you do not resolve these discrepancies, the application configuration may result in errors or result in incorrect behavior. The report generated by part 2 of the log file provides a list of joins that were not updated during the merge process. This list displays the business component name and the join name. With this list, you must go to each of the Business Component definitions and manually change the join name from the current value to the value listed in the report. Make sure that there is consistency between the joins as defined by name and the joins defined for each of the fields. Again, perform any manual configuration in the New Customer Repository after the upgrade has been run. For more information about working with Business Component definitions and joins, see Siebel Tools Online Help. |
| Siebel Database Upgrade Guide for DB2 UDB for z/OS | Copyright © 2012, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
