Enter the following command and press Enter to allocate the CLIST/EXEC library:
alloc f(sysexec) da('DSNHLQ.SIEBEL.EXEC') shr reuse
NOTE: To make sure that only Siebel executables are referenced, this command disables all CLIST libraries allocated to the logged-in user.
No message appears when the library is allocated. To verify that the exec library is listed in the file allocations by name, enter the TSO command ISRDDN.
The EXEC library DSNHLQ.SIEBEL.EXEC is used to execute all REXX execs. The panel and programs are located in this library. Execute the SBLUPG80 member from the DSNHLQ.SIEBEL.EXEC REXX library to display the Siebel Upgrade Menu; you can use this menu to navigate through the steps in the upgrade process.
TIP: The TSO command allocation for the EXEC library must be reissued with each TSO logon. Add this allocation to your personal logon CLIST to avoid having to reallocate the DSNHLQ.SIEBEL.EXEC library with each new TSO logon.
