Siebel Database Upgrade Guide for DB2 UDB for z/OS > Creating the Siebel Staging Database > Preparing the z/OS Host Upgrade Environment and Creating the Staging Database > Customizing the JCL UNIT Parameter ValueIf appropriate for your environment, you can amend the To amend the UNIT parameter setting
If you want to revert to the default NOTE: Any amendments you make to the UNIT parameter are not applied to data sets that are allocated using REXX routines. |
| Siebel Database Upgrade Guide for DB2 UDB for z/OS | Copyright © 2012, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
