Table 44.	Columns Denormalized During Upgrades from Release 6.3 Siebel Industry Solutions
    | S_ACCNT_POSTN
 | ACCNT_TYPE_CD
 | [OU_EXT_ID].[ACCNT_TYPE_CD] | S_ORG_EXT
 | ACCNT_TYPE_CD
    | S_ACCNT_POSTN
 | CLIENT_FLG
 | [OU_EXT_ID].[CLIENT_FLG] | S_ORG_EXT
 | CLIENT_FLG
    | S_ACCNT_POSTN
 | FACILITY_FLG
 | [OU_EXT_ID].[FACILITY_FLG] | S_ORG_EXT
 | FACILITY_FLG
    | S_ACCNT_POSTN
 | INVSTR_FLG
 | [OU_EXT_ID].[INVSTR_FLG] | S_ORG_EXT
 | INVSTR_FLG
    | S_ACCNT_POSTN
 | ORG_REF_CUST_FLG
 | [OU_EXT_ID].[REFERENCE_CUST_FLG] | S_ORG_EXT
 | REFERENCE_CUST_FLG
    | S_ACCNT_POSTN
 | SRV_PROVDR_FLG
 | [OU_EXT_ID].[SRV_PROVDR_FLG] | S_ORG_EXT
 | SRV_PROVDR_FLG
    | S_ACT_CAL_RSRC
 | ACT_APPT_REPT_FLG
 | [ACTIVITY_ID].[APPT_REPT_FLG] | S_EVT_ACT
 | APPT_REPT_FLG
    | S_ACT_CAL_RSRC
 | ACT_APPT_RPTEND_DT
 | [ACTIVITY_ID].[APPT_REPT_END_DT] | S_EVT_ACT
 | APPT_REPT_END_DT
    | S_ACT_CAL_RSRC
 | ACT_CAL_TYPE_CD
 | [ACTIVITY_ID].[CAL_TYPE_CD] | S_EVT_ACT
 | CAL_TYPE_CD
    | S_ACT_CAL_RSRC
 | ACT_TEMPLATE_FLG
 | [ACTIVITY_ID].[TEMPLATE_FLG] | S_EVT_ACT
 | TEMPLATE_FLG
    | S_ACT_CAL_RSRC
 | ACT_TODO_PLNEND_DT
 | [ACTIVITY_ID].[TODO_PLAN_END_DT] | S_EVT_ACT
 | TODO_PLAN_END_DT
    | S_ACT_CAL_RSRC
 | ACT_TODO_PLNSTRTDT
 | [ACTIVITY_ID].[TODO_PLAN_START_DT] | S_EVT_ACT
 | TODO_PLAN_START_DT
    | S_ACT_EMP
 | ACT_ALARM_FLG
 | [ACTIVITY_ID].[ALARM_FLAG] | S_EVT_ACT
 | ALARM_FLAG
    | S_ACT_EMP
 | ACT_APPT_REPT_FLG
 | APPT_REPT_FLG
    | S_ACT_EMP
 | ACT_APPT_RPTEND_DT
 | APPT_REPT_END_DT
    | S_ACT_EMP
 | ACT_APPT_START_DT
 | [ACTIVITY_ID].[APPT_START_DT] | S_EVT_ACT
 | APPT_START_DT
    | S_ACT_EMP
 | ACT_CAL_DISP_FLG
 | [ACTIVITY_ID].[CAL_DISP_FLG] | S_EVT_ACT
 | CAL_DISP_FLG
    | S_ACT_EMP
 | ACT_CAL_TYPE_CD
 | CAL_TYPE_CD
    | S_ACT_EMP
 | ACT_EVT_STAT_CD
 | [ACTIVITY_ID].[EVT_STAT_CD] | S_EVT_ACT
 | EVT_STAT_CD
    | S_ACT_EMP
 | ACT_TEMPLATE_FLG
 | TEMPLATE_FLG
    | S_ACT_EMP
 | ACT_TODO_PLNEND_DT
 | TODO_PLAN_END_DT
    | S_ACT_EMP
 | ACT_TODO_PLNSTRTDT
 | TODO_PLAN_START_DT
    | S_AGREE_POSTN
 | AGREE_NAME
 | [AGREE_ID].[NAME] | S_DOC_AGREE
 | NAME
    | S_AGREE_POSTN
 | AGREE_STAT_CD
 | [AGREE_ID].[STAT_CD] | S_DOC_AGREE
 | STAT_CD
    | S_AGREE_POSTN
 | AGREE_VALID_FLG
 | [AGREE_ID].[VALID_FLG] | S_DOC_AGREE
 | VALID_FLG
    | S_ASSET_BU
 | ASSET_NUM
 | [ASSET_ID].[ASSET_NUM] | S_ASSET
 | ASSET_NUM
    | S_ASSET_BU
 | TYPE_CD
 | [ASSET_ID].[TYPE_CD] | S_ASSET
 | TYPE_CD
    | S_ASSET_POSTN
 | ASSET_NUM
 | ASSET_NUM
    | S_ASSET_POSTN
 | TYPE_CD
 | TYPE_CD
    | S_CASE_BU
 | CASE_NAME
 | [CASE_ID].[NAME] | S_CASE
 | NAME
    | S_CASE_BU
 | CASE_STATUS_CD
 | [CASE_ID].[STATUS_CD] | S_CASE
 | STATUS_CD
    | S_CASE_BU
 | CASE_TYPE_CD
 | [CASE_ID].[TYPE_CD] | S_CASE
 | TYPE_CD
    | S_CONTACT_BU
 | AGENT_FLG
 | [CONTACT_ID].[AGENT_FLG] | S_CONTACT
 | AGENT_FLG
    | S_CONTACT_BU
 | CON_EMP_FLG
 | [CONTACT_ID].[EMP_FLG] | S_CONTACT
 | EMP_FLG
    | S_CONTACT_BU
 | CON_FST_NAME
 | [CONTACT_ID].[FST_NAME] | S_CONTACT
 | FST_NAME
    | S_CONTACT_BU
 | CON_LAST_NAME
 | [CONTACT_ID].[LAST_NAME] | S_CONTACT
 | LAST_NAME
    | S_CONTACT_BU
 | CON_MID_NAME
 | [CONTACT_ID].[MID_NAME] | S_CONTACT
 | MID_NAME
    | S_CONTACT_BU
 | MEMBER_FLG
 | [CONTACT_ID].[MEMBER_FLG] | S_CONTACT
 | MEMBER_FLG
    | S_CONTACT_BU
 | PROVIDER_FLG
 | [CONTACT_ID].[PROVIDER_FLG] | S_CONTACT
 | PROVIDER_FLG
    | S_CTLG_CAT_AUC
 | AUC_AUC_LOT_NUM
 | [AUC_ITEM_ID].[AUC_LOT_NUM] | S_AUC_ITEM
 | AUC_LOT_NUM
    | S_CTLG_CAT_CRSE
 | CRSE_NAME
 | [CRSE_ID].[NAME] | S_CRSE
 | NAME
    | S_CTLG_CAT_CRSE
 | CRSE_SUB_TYPE
 | [CRSE_ID].[SUB_TYPE] | S_CRSE
 | SUB_TYPE
    | S_CTLG_CAT_DFCT
 | DFCT_DFCT_NUM
 | [PROD_DEFECT_ID].[DEFECT_NUM] | S_PROD_DEFECT
 | DEFECT_NUM
    | S_CTLG_CAT_ISS
 | ISS_NAME
 | [ISS_ID].[NAME] | S_ISS
 | NAME
    | S_CTLG_CAT_LIT
 | LIT_NAME
 | [LIT_ID].[NAME] | S_LIT
 | NAME
    | S_CTLG_CAT_ORG
 | ORG_CMPT_FLG
 | [ORG_ID].[CMPT_FLG] | S_ORG_EXT
 | CMPT_FLG
    | S_CTLG_CAT_ORG
 | ORG_LOC
 | [ORG_ID].[LOC] | S_ORG_EXT
 | LOC
    | S_CTLG_CAT_ORG
 | ORG_NAME
 | [ORG_ID].[NAME] | S_ORG_EXT
 | NAME
    | S_CTLG_CAT_ORG
 | ORG_PRTNR_FLG
 | [ORG_ID].[PRTNR_FLG] | S_ORG_EXT
 | PRTNR_FLG
    | S_CTLG_CAT_PROD
 | PROD_EFF_END_DT
 | [PROD_ID].[EFF_END_DT] | S_PROD_INT
 | EFF_END_DT
    | S_CTLG_CAT_PROD
 | PROD_EFF_START_DT
 | [PROD_ID].[EFF_START_DT] | S_PROD_INT
 | EFF_START_DT
    | S_CTLG_CAT_PROD
 | PROD_NAME
 | [PROD_ID].[NAME] | S_PROD_INT
 | NAME
    | S_CTLG_CAT_SR
 | SR_SR_NUM
 | [SRV_REQ_ID].[SR_NUM] | S_SRV_REQ
 | SR_NUM
    | S_CTLG_CAT_SRC
 | SRC_NAME
 | [SRC_ID].[NAME] | S_SRC
 | NAME
    | S_CTLG_CAT_SRC
 | SRC_SRC_NUM
 | [SRC_ID].[SRC_NUM] | S_SRC
 | SRC_NUM
    | S_CTLG_CAT_SRC
 | SRC_SUB_TYPE
 | [SRC_ID].[SUB_TYPE] | S_SRC
 | SUB_TYPE
    | S_CTLGCAT_ASSET
 | ASSET_ASSET_NUM
 | ASSET_NUM
    | S_CTLGCAT_ASSET
 | ASSET_SERIAL_NUM
 | [ASSET_ID].[SERIAL_NUM] | S_ASSET
 | SERIAL_NUM
    | S_CTLGCAT_PATH
 | CS_PATH_NAME
 | [CS_PATH_ID].[NAME] | S_CS_PATH
 | NAME
    | S_CTLGCT_RESITM
 | RI_INTR_PUBL_FLG
 | [RES_ITEM_ID].[INTR_PUBLISH_FLG] | S_RES_ITEM
 | INTR_PUBLISH_FLG
    | S_CTLGCT_RESITM
 | RI_NAME
 | [RES_ITEM_ID].[NAME] | S_RES_ITEM
 | NAME
    | S_CTLGCT_RESITM
 | RI_TYPE_CD
 | [RES_ITEM_ID].[TYPE_CD] | S_RES_ITEM
 | TYPE_CD
    | S_DOC_AGREE_BU
 | AGREE_NAME
 | [AGREEMENT_ID].[NAME] | S_DOC_AGREE
 | NAME
    | S_DOC_AGREE_BU
 | AGREE_STAT_CD
 | [AGREEMENT_ID].[STAT_CD] | S_DOC_AGREE
 | STAT_CD
    | S_DOC_AGREE_BU
 | AGREE_VALID_FLG
 | [AGREEMENT_ID].[VALID_FLG] | S_DOC_AGREE
 | VALID_FLG
    | S_DOC_PPSL_BU
 | PPSL_DFLT_TMPL_FLG
 | [DOC_PPSL_ID].[DFLT_TEMPLATE_FLG] | S_DOC_PPSL
 | DFLT_TEMPLATE_FLG
    | S_DOC_PPSL_BU
 | PPSL_NAME
 | [DOC_PPSL_ID].[NAME] | S_DOC_PPSL
 | NAME
    | S_DOC_PPSL_BU
 | PPSL_TEMPLATE_FLG
 | [DOC_PPSL_ID].[TEMPLATE_FLG] | S_DOC_PPSL
 | TEMPLATE_FLG
    | S_DOC_PPSL_BU
 | PPSL_TYPE_CD
 | [DOC_PPSL_ID].[PPSL_TYPE_CD] | S_DOC_PPSL
 | PPSL_TYPE_CD
    | S_DOC_QUOTE_BU
 | DOC_QTE_NUM
 | [DOC_QUOTE_ID].[QUOTE_NUM] | S_DOC_QUOTE
 | QUOTE_NUM
    | S_DOC_QUOTE_BU
 | DOC_QTE_REV_NUM
 | [DOC_QUOTE_ID].[REV_NUM] | S_DOC_QUOTE
 | REV_NUM
    | S_DOC_QUOTE_BU
 | DOC_QUOTE_NAME
 | [DOC_QUOTE_ID].[NAME] | S_DOC_QUOTE
 | NAME
    | S_INSCLM_BU
 | INSCLAIM_NUM
 | [INSCLM_ID].[INSCLAIM_NUM] | S_INS_CLAIM
 | INSCLAIM_NUM
    | S_INSCLM_BU
 | REV_NUM
 | [INSCLM_ID].[REVISION_NUM] | S_INS_CLAIM
 | REVISION_NUM
    | S_INSCLMEL_BU
 | SEQ_NUM
 | [INSCLM_ELMNT_ID].[SEQ_NUM] | S_INSCLM_ELMNT
 | SEQ_NUM
    | S_INSCLMEL_BU
 | TYPE_CD
 | [INSCLM_ELMNT_ID].[TYPE_CD] | S_INSCLM_ELMNT
 | TYPE_CD
    | S_INV_TXN_BU
 | INV_TXN_NUM
 | [INV_TXN_ID].[INV_TXN_NUM] | S_INV_TXN
 | INV_TXN_NUM
    | S_ISS_BU
 | ISS_LANG_ID
 | [ISS_ID].[LANG_ID] | S_ISS
 | LANG_ID
    | S_ISS_BU
 | ISS_NAME
 | NAME
    | S_LOY_MEM_BU
 | MEM_NUM
 | [MEMBER_ID].[MEM_NUM] | S_LOY_MEMBER
 | MEM_NUM
    | S_LOY_MEM_BU
 | MEM_TYPE_CD
 | [MEMBER_ID].[MEM_TYPE_CD] | S_LOY_MEMBER
 | MEM_TYPE_CD
    | S_LOY_MEM_PSTN
 | MEM_NUM
 | MEM_NUM
    | S_LOY_MEM_PSTN
 | MEM_TYPE_CD
 | MEM_TYPE_CD
    | S_LOY_PROG_BU
 | PROG_NAME
 | [PROG_ID].[NAME] | S_LOY_PROG
 | NAME
    | S_LOY_PROMO_BU
 | PROMO_NAME
 | [PROMO_ID].[NAME] | S_LOY_PROMO
 | NAME
    | S_LOY_PROMO_BU
 | PROMO_NUM
 | [PROMO_ID].[PROMO_NUM] | S_LOY_PROMO
 | PROMO_NUM
    | S_LOY_TXN_BU
 | TXN_NUM
 | [TXN_ID].[TXN_NUM] | S_LOY_TXN
 | TXN_NUM
    | S_LOY_TXN_BU
 | TXN_STATUS_CD
 | [TXN_ID].[STATUS_CD] | S_LOY_TXN
 | STATUS_CD
    | S_LOY_TXN_BU
 | TXN_SUB_TYPE_CD
 | [TXN_ID].[SUB_TYPE_CD] | S_LOY_TXN
 | SUB_TYPE_CD
    | S_LOY_TXN_BU
 | TXN_TYPE_CD
 | [TXN_ID].[TYPE_CD] | S_LOY_TXN
 | TYPE_CD
    | S_MDF_BU
 | MDF_UID
 | [MDF_ID].[MDF_UID] | S_MDF
 | MDF_UID
    | S_OPTY_BU
 | OPTY_NAME
 | [OPTY_ID].[NAME] | S_OPTY
 | NAME
    | S_OPTY_BU
 | SUM_CLASS_CD
 | [OPTY_ID].[SUM_CLASS_CD] | S_OPTY
 | SUM_CLASS_CD
    | S_OPTY_BU
 | SUM_COMMIT_FLG
 | [OPTY_ID].[SUM_COMMIT_FLG] | S_OPTY
 | SUM_COMMIT_FLG
    | S_OPTY_BU
 | SUM_COST_AMT
 | [OPTY_ID].[SUM_COST_AMT] | S_OPTY
 | SUM_COST_AMT
    | S_OPTY_BU
 | SUM_DOWNSIDE_AMT
 | [OPTY_ID].[SUM_DOWNSIDE_AMT] | S_OPTY
 | SUM_DOWNSIDE_AMT
    | S_OPTY_BU
 | SUM_EFFECTIVE_DT
 | [OPTY_ID].[SUM_EFFECTIVE_DT] | S_OPTY
 | SUM_EFFECTIVE_DT
    | S_OPTY_BU
 | SUM_MARGIN_AMT
 | [OPTY_ID].[SUM_MARGIN_AMT] | S_OPTY
 | SUM_MARGIN_AMT
    | S_OPTY_BU
 | SUM_REVN_AMT
 | [OPTY_ID].[SUM_REVN_AMT] | S_OPTY
 | SUM_REVN_AMT
    | S_OPTY_BU
 | SUM_TYPE_CD
 | [OPTY_ID].[SUM_TYPE_CD] | S_OPTY
 | SUM_TYPE_CD
    | S_OPTY_BU
 | SUM_UPSIDE_AMT
 | [OPTY_ID].[SUM_UPSIDE_AMT] | S_OPTY
 | SUM_UPSIDE_AMT
    | S_OPTY_BU
 | SUM_WIN_PROB
 | [OPTY_ID].[SUM_WIN_PROB] | S_OPTY
 | SUM_WIN_PROB
    | S_OPTY_POSTN
 | CONSUMER_OPTY_FLG
 | [OPTY_ID].[CONSUMER_OPTY_FLG] | S_OPTY
 | CONSUMER_OPTY_FLG
    | S_OPTY_POSTN
 | NEW_LOAN_FLG
 | [OPTY_ID].[NEW_LOAN_FLG] | S_OPTY
 | NEW_LOAN_FLG
    | S_OPTY_POSTN
 | OPTY_CLOSED_FLG
 | [OPTY_ID].[CLOSED_FLG] | S_OPTY
 | CLOSED_FLG
    | S_OPTY_POSTN
 | OPTY_NAME
 | NAME
    | S_OPTY_POSTN
 | SECURE_FLG
 | [OPTY_ID].[SECURE_FLG] | S_OPTY
 | SECURE_FLG
    | S_OPTY_POSTN
 | SUM_CLASS_CD
 | SUM_CLASS_CD
    | S_OPTY_POSTN
 | SUM_COMMIT_FLG
 | SUM_COMMIT_FLG
    | S_OPTY_POSTN
 | SUM_COST_AMT
 | SUM_COST_AMT
    | S_OPTY_POSTN
 | SUM_DOWNSIDE_AMT
 | SUM_DOWNSIDE_AMT
    | S_OPTY_POSTN
 | SUM_EFFECTIVE_DT
 | SUM_EFFECTIVE_DT
    | S_OPTY_POSTN
 | SUM_MARGIN_AMT
 | SUM_MARGIN_AMT
    | S_OPTY_POSTN
 | SUM_REVN_AMT
 | SUM_REVN_AMT
    | S_OPTY_POSTN
 | SUM_TYPE_CD
 | SUM_TYPE_CD
    | S_OPTY_POSTN
 | SUM_UPSIDE_AMT
 | SUM_UPSIDE_AMT
    | S_OPTY_POSTN
 | SUM_WIN_PROB
 | SUM_WIN_PROB
    | S_ORDER_BU
 | ORDER_CAT_CD
 | [ORDER_ID].[ORDER_CAT_CD] | S_ORDER
 | ORDER_CAT_CD
    | S_ORDER_BU
 | ORDER_DT
 | [ORDER_ID].[ORDER_DT] | S_ORDER
 | ORDER_DT
    | S_ORDER_BU
 | ORDER_NUM
 | [ORDER_ID].[ORDER_NUM] | S_ORDER
 | ORDER_NUM
    | S_ORDER_POSTN
 | ORDER_CAT_CD
 | ORDER_CAT_CD
    | S_ORDER_POSTN
 | ORDER_DT
 | ORDER_DT
    | S_ORDER_POSTN
 | ORDER_NUM
 | ORDER_NUM
    | S_ORG_BU
 | ORG_CMPT_FLG
 | CMPT_FLG
    | S_ORG_BU
 | ORG_FACILITY_FLG
 | [ORG_ID].[FACILITY_FLG] | S_ORG_EXT
 | FACILITY_FLG
    | S_ORG_BU
 | ORG_INVSTR_FLG
 | [ORG_ID].[INVSTR_FLG] | S_ORG_EXT
 | INVSTR_FLG
    | S_ORG_BU
 | ORG_LOC
 | LOC
    | S_ORG_BU
 | ORG_NAME
 | NAME
    | S_ORG_BU
 | ORG_PRTNR_FLG
 | PRTNR_FLG
    | S_ORG_BU
 | ORG_REF_CUST_FLG
 | [ORG_ID].[REFERENCE_CUST_FLG] | S_ORG_EXT
 | REFERENCE_CUST_FLG
    | S_ORG_BU
 | ORG_SRV_PROVDR_FLG
 | [ORG_ID].[SRV_PROVDR_FLG] | S_ORG_EXT
 | SRV_PROVDR_FLG
    | S_ORG_DIST_LST
 | OU_ID
 | [ORG_PROD_ID].[OU_ID] | S_ORG_PROD
 | OU_ID
    | S_ORG_GROUP_BU
 | OG_GROUP_NAME
 | [ORG_GROUP_ID].[GROUP_NAME] | S_ORG_GROUP
 | GROUP_NAME
    | S_ORG_GROUP_BU
 | OG_GROUP_TYPE_CD
 | [ORG_GROUP_ID].[GROUP_TYPE_CD] | S_ORG_GROUP
 | GROUP_TYPE_CD
    | S_ORG_GROUP_BU
 | OG_NAME
 | [ORG_GROUP_ID].[NAME] | S_ORG_GROUP
 | NAME
    | S_ORGGRP_POSTN
 | GROUP_TYPE_CD
 | [ORGGRP_ID].[GROUP_TYPE_CD] | S_ORG_GROUP
 | GROUP_TYPE_CD
    | S_ORGGRP_POSTN
 | GRP_GROUP_NAME
 | [ORGGRP_ID].[GROUP_NAME] | S_ORG_GROUP
 | GROUP_NAME
    | S_ORGGRP_POSTN
 | GRP_NAME
 | [ORGGRP_ID].[NAME] | S_ORG_GROUP
 | NAME
    | S_PARTY_GRP_BU
 | PG_NAME
 | [PARTY_GROUP_ID].[NAME] | S_PARTY_GROUP
 | NAME
    | S_PERIOD_BU
 | PERIOD_NAME
 | [PERIOD_ID].[NAME] | S_PERIOD
 | NAME
    | S_POS_BU
 | POS_NUM
 | [POS_ID].[POS_NUM] | S_POS
 | POS_NUM
    | S_POSTN_CON
 | AGENT_FLG
 | [CON_ID].[AGENT_FLG] | S_CONTACT
 | AGENT_FLG
    | S_POSTN_CON
 | MEMBER_FLG
 | [CON_ID].[MEMBER_FLG] | S_CONTACT
 | MEMBER_FLG
    | S_POSTN_CON
 | PROVIDER_FLG
 | [CON_ID].[PROVIDER_FLG] | S_CONTACT
 | PROVIDER_FLG
    | S_PRIFCTR_ITM
 | PRIMDL_ID
 | [PRIMDL_FCTR_ID].[PRIMDL_ID] | S_PRIMDL_FCTR
 | PRIMDL_ID
    | S_PROD_DFCT_BU
 | DEFECT_NUM
 | DEFECT_NUM
    | S_PROD_INT_BU
 | PROD_CD
 | [PROD_INT_ID].[PROD_CD] | S_PROD_INT
 | PROD_CD
    | S_PROD_INT_BU
 | PROD_EFF_END_DT
 | [PROD_INT_ID].[EFF_END_DT] | S_PROD_INT
 | EFF_END_DT
    | S_PROD_INT_BU
 | PROD_EFF_START_DT
 | [PROD_INT_ID].[EFF_START_DT] | S_PROD_INT
 | EFF_START_DT
    | S_PROD_STYL_TNT
 | SETUP_STYLE_CD
 | [PROP_STYLE_ID].[SETUP_STYLE_CD] | S_PROP_STYL_TNT
 | SETUP_STYLE_CD
    | S_PROJ_BU
 | PROJ_NAME
 | [PROJ_ID].[NAME] | S_PROJ
 | NAME
    | S_PROJ_BU
 | PROJ_STATUS_CD
 | [PROJ_ID].[STATUS_CD] | S_PROJ
 | STATUS_CD
    | S_PROJ_BU
 | PROJ_TYPE_CD
 | [PROJ_ID].[PROJ_TYPE_CD] | S_PROJ
 | PROJ_TYPE_CD
    | S_PSP_PROC_BU
 | VOD_NAME
 | [VOD_ID].[VOD_NAME] | S_VOD
 | VOD_NAME
    | S_QUOTE_POSTN
 | QUOTE_NUM
 | [QUOTE_ID].[QUOTE_NUM] | S_DOC_QUOTE
 | QUOTE_NUM
    | S_SALES_MTHD_BU
 | SALES_METHOD_NAME
 | [SALES_METHOD_ID].[NAME] | S_SALES_METHOD
 | NAME
    | S_SRC_BU
 | SRC_NAME
 | NAME
    | S_SRV_REQ_BU
 | SR_AREA
 | [SRV_REQ_ID].[SR_AREA] | S_SRV_REQ
 | SR_AREA
    | S_SRV_REQ_BU
 | SR_CST_NUM
 | [SRV_REQ_ID].[SR_CST_NUM] | S_SRV_REQ
 | SR_CST_NUM
    | S_SRV_REQ_BU
 | SR_NUM
 | SR_NUM
    | S_SRV_REQ_BU
 | SR_SEV_CD
 | [SRV_REQ_ID].[SR_SEV_CD] | S_SRV_REQ
 | SR_SEV_CD
    | S_SRV_REQ_BU
 | SR_STAT_ID
 | [SRV_REQ_ID].[SR_STAT_ID] | S_SRV_REQ
 | SR_STAT_ID
    | S_SRV_REQ_BU
 | SR_SUB_STAT_ID
 | [SRV_REQ_ID].[SR_SUB_STAT_ID] | S_SRV_REQ
 | SR_SUB_STAT_ID
    | S_SRV_REQ_BU
 | SR_TITLE
 | [SRV_REQ_ID].[SR_TITLE] | S_SRV_REQ
 | SR_TITLE
    | S_SRV_REQ_BU
 | SR_TYPE_CD
 | [SRV_REQ_ID].[SR_TYPE_CD] | S_SRV_REQ
 | SR_TYPE_CD
    | S_TMPL_PLNIT_BU
 | PLANITEM_NAME
 | [TMPL_PLANITEM_ID].[NAME] | S_TMPL_PLANITEM
 | NAME
    | S_TMPL_PLNIT_BU
 | PLANITEM_TYPE_CD
 | [TMPL_PLANITEM_ID].[TYPE_CD] | S_TMPL_PLANITEM
 | TYPE_CD
    | S_TMPL_PLNIT_BU
 | PLNIT_TMPL_TYPE_CD
 | [TMPL_PLANITEM_ID].[TMPL_TYPE_CD] | S_TMPL_PLANITEM
 | TMPL_TYPE_CD
    | S_USERLIST_BU
 | UL_NAME
 | [USERLIST_ID].[NAME] | S_USERLIST
 | NAME
    | S_WRNTY_CVRG_BU
 | WRNTY_CVRG_NAME
 | [WRNTY_CVRG_ID].[WRNTY_NAME] | S_WRNTY_CVRG
 | WRNTY_NAME
    | T_MASTER_BU
 | MASTER_ALIAS
 | [MASTER_ID].[ALIAS] | T_MASTER
 | ALIAS
    | T_MASTER_BU
 | MASTER_NAME
 | [MASTER_ID].[NAME] | T_MASTER
 | NAME
    | T_MASTER_DETAIL
 | DETAIL_SX2_NAME
 | [DETAIL_SX2_ID].[SX2_NAME] | T_DETAIL_SX2
 | SX2_NAME
    | T_MASTER_DETAIL
 | MASTER_NAME
 | NAME
    | T_MASTER_PER
 | MASTER_ALIAS
 | ALIAS
    | T_MASTER_POSTN
 | MASTER_NAME
 | NAME
