Table 39. Obsolete Siebel Marketing Data as of Release 7.7
Obsolete Business Components |
Programs (program occurrences) |
Obsolete |
None |
None |
Activities migrated to parent program. |
Stages (stage occurrences) |
Obsolete |
Campaigns (campaign occurrences) |
Obsolete |
None |
DBM Campaign Campaign Occurrences Campaign Occurrences Delete Campaign Results Campaign Segment Allocation Campaign Template Related Event Templates Campaign Wave List Distribution DBM Campaign Cost DBM Campaign Cost (Fixed) DBM Campaign Cost (Inbound) DBM Campaign Cost (Outbound) DBM Campaign Occurrence Cost DBM Campaign Occurrence Lists Campaign Occurrence Offer DBM Preview List |
A campaign load record is created for each occurrence. |
eNewsletter Offers |
Obsolete |
Enewsletter Offer Enewsletter Offer Attachments Enewsletter Offer Attachments.Sequence Number (Sequence) Enewsletter Offer Comm Profile Parameter Enewsletter Offer Related URLs Enewsletter Offer Template Related Web Offers f/ Enewsletter Offer Related Web Surveys f/ Enewsletter Offer |
Newsletter functionality is supported by conditional content formatting in email offers. |
Segments |
Usage history in programs is preserved. Segment criteria are obsolete. |
S_CALL_LST_CRIT S_CALL_LST_DTL S_CALL_LST_QRY |
Segment Detail-DD Segment Expression Campaign Segment Allocation Segment Campaign Allocation |
Segments should be reconstructed in the Segment Designer. |
Filters |
Obsolete |
S_DD_FILTER S_DD_FILTER_DTL |
Filters Filters Detail Filters Expression Save Attribute Level Look Up |
Filters should be applied using criteria in the Segment Designer or Segment Tree Designer or metadata constraints in the Siebel Analytics repository. |
List Formats |
Obsolete |
S_DD_LST_FMT S_DD_LST_FMTDTL S_DD_PROGLSTFMT |
List Columns List Columns.Sequence (Sequence) List Formats Program List Formats Dependent List Format |
Create List Formats using the List Format Designer. |
Source Code Formats |
Obsolete |
None |
None |
Old source code formats are obsolete. After upgrade, source code formats need to be re-created with new elements. |
Tables Joins |
Obsolete |
S_DD_DATA_OBJ S_DD_UNION_MBR S_DD_JOIN S_DD_JOIN_SPEC |
DD Field DD Join DD Table Fields One Level Join Fields Join Fields.Sequence (Sequence) Union Tables |
All data source metadata is managed in the Siebel Analytics repository. |
List Measures Bound Measures Custom Measures |
Obsolete |
S_DD_MEAS S_DD_MEASRSTRCT S_DD_SUBMEAS |
Aggregation Function Available Measures Base Measure Bound Measures Custom Measures Dependent List Format Functions (Logical) Functions (Mathematical) List Measures Measures Parent Measures RowNum Measure SubMeasures Measure Aggregation (Tree) Members.Sequence (Sequence) Measure Restrict Measure Restrict (Tree) |
Replaced by formulas in the Siebel Analytics repository. |
Buckets (Measure Base Attributes) |
Obsolete |
S_DD_MEASATRPAR S_DD_MEAS_ATTR |
Measure Attribute Members Measure Attribute Members (Tree) Measure Attribute Measure Attributes Measure Attributes (Tree) |
Attributes and Attribute Families |
Obsolete |
S_DD_ATRFAMLVMB S_DD_ATTRFAM S_DD_ATTRFAMLVL S_DD_ATTRFAMVAL S_DD_FIELD S_DD_HIERATR S_DD_HIERATRKEY S_DD_HIERATRLVL S_DD_HIERATRVAL |
Attribute Families Attribute Family Resync VBC Attribute Family Value Attribute Filters Detail Attribute Levels Attribute Levels.Sequence (Sequence) Hierarchical Attribute Value Hierarchical Attributes Hierarchy (Fields) Hierarchy (Tree) Hierarchy Levels (Tree) Hierarchy Levels Search (Tree) Hierarchy Search (Fields) Hierarchy Search (Tree) Hierarchy Values (Fields) Hierarchy Values (Tree) Hierarchy.Sequence (Sequence) |
Segment criteria are now created using presentation columns (fields) in the Segment Designer. |
Customer Hierarchies |
Obsolete |
S_DD_STRFAM S_DD_SRTFAM_LVL S_DD_SRTFAM_MAP |
Hierarchy Hierarchy Levels Hierarchy Levels (Fields) User Defined Levels User Defined Levels.Sequence (Sequence) |
No longer necessary. Customer-level targeting is supported by Target Levels in the Siebel Analytics repository. |
Campaign Load Mappings (Contact Key Formats) |
Obsolete |
Server tables (internal use) |
Obsolete |
S_DD_CUBE S_DD_DIM S_DD_DIM_DTL S_DD_EXTRACT S_DD_EXTRACT_CL S_DD_PROGEXPORT S_DD_SNPSHT_FMT S_DD_PRPERFMEAS |
Snapshot Elements |
These tables were used by obsolete Siebel Server Components (Data Dictionary Manager and Marketing Server). |
